Question about CD Players
How do install a intalation dick manually, as i cant get get to run on auto
  • 103 Answers
Re: How do install a intalation dick manually, as i cant...
Er, do you mean installation disk!?
Sounds like you have autorun disabled. So put the disk in, find it on my computer & double click it. You should see a list of files. Look for something called "autorun" or the application (will end in ".exe") and you should be up & running.
You can enable autorun for future use, but it is not as easy a job as you might expect. Assuming you are running Windows, there is some help here:
But do NOT do this unless you are sure what you are doing. Otherwise you might end up having to reinstall Windows, which is even more of a pain.
Posted on Jan 08, 2008
0 characters
3 Points
Ho to programme jukebox
email me for full manual
Jul 06, 2014 | CD Players
I have a misubishi cd and casette player out of a jeep model #P04704383AD date code 3447 supplier28046 serial #T00AM3447B0509 I need the wiring diagram its doing into a ford explorer
The easist way to install it ,Is to get a wireing kit from a car audio supply store for your ford, As long as the radio harrness isn,t cut off you can get a wireing kit that plugs in to the factory harness, I installed car audio equipment for over 40 years, Untill i retired this summer, End a llways use a kit,If some one didn,t cut the harness of, If they did cut the factory harness off,I would go end get one from a auto wrecker ,End put it in all so. It makes it a hake of a lot (Easier) to install, Hope this hels you out,
Nov 08, 2012 | CD Players
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
I want to know how to track c.d. when recording,I don't have a remote??
If you mean you don't know how to manually mark a track in Manual Mode >>while<< recording on the fly:
Toggle the Auto/Manual button to Manual
Press the SKIP/Search right arrow button for tray B while recording whenever you want to increment the track number.
Pausing or stopping the recording also increments the next track number. There is no way to manipulate the actual number assigned to any track. It is alway PLUS 1 from the last track.
I always use Manual track numbering on my Pioneer machine when recording analog sources because many machines (like yours) will interpret a short silence as a track break. This may not necessarily be what you want to happen.
Feb 24, 2010 | RCA CDRW120 2-Disc CD Recorder
Problem with cd player not playing i cant find the parts i need and cant find searvice manuals and manuals for mi pioneer resever vsx 305 and my cd player pd 202
if the problem is with the lens and you can't get it clean, or the spindle motor does not spin, you'll need to replace the whole optical pickup. try mcm electronics. you may need to give them the actual part number from the pickup assembly.
Jan 12, 2010 | CD Players
Im trying to records mix cd but isnt changing
• To switch off the Auto Track function you have to enter
Menu mode.
If you wish to increase track numbers manually, press
TRACK INCR(ement) on the remote control. For further
instructions see Menu mode.
ON (AUTO): The track increments are automatically taken over
from the digital source material or after 2.7
seconds silence during analog recording.
OFF (MANUAL): While recording track numbers can be
incremented manually by pressing TRACK
(Minimum track length is 4 sec.) (This can
also be done in Auto track ON mode.)
May 01, 2009 | Philips CDR770 CD Recorder
Need to download the recorded media to a computer.. any special step because the hd on the cdr420 isnt; pullin up??? i dont have the manual and cant find it...manual would be helpful to have too...
Hi, i have located the manual for this device. you can access it and, print it out as well if you choose. the link to your manual is below.
Please rate and god bless:)
Apr 17, 2009 | Marantz CDR420 CD Recorder
the problem is, there is no way to add a pdf to this forum, I have the PDF and cannot share it with you---here is an e-m, ------good luck from -----newbie
Oct 23, 2008 | KLH CDR2000 2-Disc CD Recorder
heres the manual link print out manual and save
from manual discription the feature your looking for is on the front deck single auto repeat, repeat, single
i hope this is what your looking for
May 07, 2008 | Tascam CD-450 CD Player
Recording from a Digital Source (computer)
Your computer audio output is definatley digital, yes? If so, make sure it is set to 2-channel PCM digital output, not 5,1 Dolby digital surround sound output. Auto / manual on the unit is for track marks to be inserted during recording. If you google the manual is out there or I can email it.
Jan 15, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
CD Players Logo
37 people viewed this question
Top CD Players Experts
Dave Jukebox
Are you a CD Player Expert? Answer questions, earn points and help others
