Question about Epson Stylus Photo R200 InkJet Printer
Epsom R200 COPY INK DOESNT WORK
Replaced Epsom ink cartridge with compatable copy ink cartridge, but printer will not print ( A big red x comes up on the screen indicating the replaced ink is not acceptable)..i have used these inks many times before but not with this printer..can you help?..thanks.
  • Anonymous Feb 12, 2008
    have been using S-vision compatible cartridges for ages on my r200. just changed the whole set and can't get the printer to recognise them. keep switching off and on ..sometimes get one x'd out or two or sometimes whole lot x'd out
    Problem Solver:
  • 5 Answers
There is no solution, I have tried this myself, there are compatible inks for this product, you just got the wrong ones, However it may only be down to one of the inks, check the ink levels before removing, if all empty, then they are not compatible.
swampduck
Posted on Feb 05, 2008
6ya staff
SOURCE:
Epson printer will not print any copies. I get the message "change cartridges 98/99." I did change both cartidges and can't clear the message and print copies.
i assume that everytime you try to print you get the same message. i sometimes get cartridge unrecognised on my epsom. I have to remove the cartridge, wipe the chip on the cartridge and reinsert.
If this doesnt work please specify printer model and if using original epsom cartridges.
Nov 15, 2011 | Office Equipment & Supplies
Replaced all ink cartridges with epsom cartridges. Printer shows ink incompativble- replaced with identical cartidges and printer wont print
the inks u had replaced might not be the compatible with ur printer you need to change another inks which are compatible only
Jan 26, 2011 | Office Equipment & Supplies
My epsom r200 has both red lights flashin when i turn it on how do i cure this prob?
Please check all of the printer doors are closed. If it is closed properly check the cartridge. If the ink is low please change the cartridge.
Aug 06, 2010 | Epson Stylus Photo R200 InkJet Printer
Epsom photo r200 ink issues
Unfortunately no there is not. However, when those are refilled the kill chips should be reset and the cartridge should function same as new. If you are not getting this result I would not buy ink from that supplier anymore. Cartridge World 100% guarantees their cartridges and will always reset the chips.
Jan 14, 2010 | Epson Stylus Photo R200 InkJet Printer
Epsom R200 printer - ink and paper lights flashing red.
theres a guide on how to manually reset the counter here
unless you replace or clean the waste pad from here on in regard your printer as a ticking ink bomb. put it on a tray with a lip just incase of an ink overflow and dont put it on the carpet.
Sep 25, 2009 | Epson Stylus Photo R200 InkJet Printer
Help
You can probably access the back of the printer to see if there is paper jammed there and remove it if there is.Normally there is an indication as to which ink cartridge needs replacing On some printers when one opens the cover the print head will move to a point which will indicate which cartridge needs replacing..
Feb 06, 2009 | Epson Stylus Photo R200 InkJet Printer
Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Oct 18, 2008 | Epson Premium Compatible** Inkjet...
Epsom Rx620 states use originals for ink cartridges
Try to hold down both 'stop' and 'B&W' button when you press the 'on' button to start the printer machine. This should erase the error message and let you print.
Regards.
Gordon
Sep 25, 2008 | Epson RX620 All-In-One InkJet Photo...
Ink level
i used Epson R230 inkjet printer.Now the printer, two lights are blinking .the messge show service requird .
Aug 04, 2008 | Epson Stylus Photo R200 InkJet Printer
Epsom printer dx7450
you could have one of several problems here.
i,d suggest printing several test pages, and observe whether the red comes through after this.
if this does,nt work remove the cartridge, and replace ensuring the cartridge goes in with a firm click.
finally if you have the original software installed for the printer, try a head cleaning operation.
Mike @ Compurepair.
Jun 22, 2008 | Epson Stylus C60 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
250 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
