Question about GE 36 in. Profile JGP963 Stainless Steel Gas Cooktop
Ge 36 I have a GE 36" gas cooktop stove, JGP962SEC2SS and I had a small fire do to the poor design of the ignitors. I need to replace them, but cannot figure out how to get at them without removing the whole unit.
  • bucmag Nov 17, 2008
    spilled water on control knobs, big fire, now light manually, where do I get
    the replacement parts?
I had the same thing happen to my cooktop. in order to replace the igniters you will have to wemove the cooktop from the counter, then you will find 4 screws on the front edge and one on each side edge that you will have to remove. Then you will need a torx screwdriver to remove each of the burners (2 screws per burner) then you can remove the top giving access to the igniters. Ours caught fire when some milk got spilled in one of the control knob holes shorting out the hot lead to ground (it is the grey wire looping from each of the igniter switches). Obviously they are not "sealed " that well, or this wouldn't have happened. I now just need to locate a source for the new parts. In the mean time I guess we will use a manual striker to ignite the stove with, or bypass the burned igniter. Hope this helps
Posted on Jun 09, 2008
    Master:
  • 619 Answers
You may need to consult near you an electrial engineer this couild be happened you need to design all parts of igniton line / many thing to change replace the switch knobs iugniter tips terminals and wirings also high voltage igniter coil. so many thing thing to buy.
Posted on Jan 10, 2008
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
My GE downdraft cooktop model JGP656 will not come up, so what could be the probelm.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 06, 2010 | GE 36 in. JGP656 Gas Cooktop
One of my cooktop knobs won't activate the ignitor
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Mar 28, 2010 | GE 36 in. JGP628 Gas Cooktop
Need replacement drip pans for ge xl44 gas stove
u can find the parts only in the service center of GE appliance center.but if ur unit is more than 10 years,im sure no parts available.
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Poor gas flow to GE cooktop
Try a bigger inlet pipe sounds like pipe too small for load .
Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Nov 22, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
Gas not igniting
aknot, make sure each burner cap has a good ground to the burner. You can use some light sandpaper to scrub them. Where the burner fits around the ignitor is a small orfice. Use a paper clip or small sharp object to clean out the orfice. Try this first. Catriver..post back.
Mar 19, 2007 | GE 36 in. Profile JGP963 Stainless Steel...
GE 36 in. Profile JGP963 Stainless Steel Gas Cooktop Logo
262 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
