Question about La Crosse K2-100 Wrist Watch
Broken writ band
My watch's black rubber wrist band broke. The problem is, I'm living in Malaysia and I bought the watch through a friend. Any viable solution?
  • 40 Answers
SOURCE: versace watch
call an authorized retailer in your area and they will be able to order a band for you. Here is a link for the website
Posted on Feb 09, 2007
  • 944 Answers
SOURCE: ks-100 sports watch
Here is the form used to contact lacrosse for a watchband; or you can use; Here is the user guide for your watch if you need it; Hope this helps :)
Posted on Apr 14, 2007
SOURCE: Invicta 2875 wrist watch band too large
take it to a jeweler and they will do it for a small cost. Usually less than $10
Posted on Dec 12, 2007
  • 3 Answers
SOURCE: Remove link form Relic Wrist band
For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
Hope this works for you!
Posted on Mar 04, 2008
  • 2334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
  • 2501 Answers
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Posted on Jan 26, 2010
Testimonial: "THANK YOU"
0 characters
1 Points
I have a Oakley Blade @ watch that's perfect except the rubber watch band broke and they say its discontinued. How can I fix it?
You may be able to find it on the internet. Once they stop making the parts you have to fend for yourself.
hope this helps. gabe
Oct 20, 2014 | Oakley Blade OAK0532 Wrist Watch
How to repair my broken wrist band
The local SEARS store has a watch-repair department.
May 19, 2014 | Sportline Solo 910M Heart Rate Watch
I bought my husband a Kenneth Cole Reaction watch with a black rubber band Code:NC1398 c275-47. The rubber band needs replacing because it is broken. Would you please know where I can order a new band for...
Try looking for a local Fast Fix jewelery repair.
They're in most malls nation wide,they will have one right in the store plus they do repairs for a nominal fee.
Hope this helps you a vote would be nice,Gary
Dec 01, 2010 | Kenneth Cole KC1104 Wrist Watch
I need a replacement bracelet for my Cartier 21 Chronoscaph watch?
My black rubber watch band is cracked and in need of replacement. I refuse to shell out $500 for another rubber band from Cartier. This is my first and last Cartier watch... Poor customer service on a very expensive watch.
500 per one rubber; is not expensive is a steal
Sep 24, 2010 | Cartier 21 Chronoscaph W10125U2 Wrist...
The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
Jul 21, 2010 | Seiko SGF204 Wrist Watch
I have a wonderful cardinal digital watch that I just love. I received this as a Christmas present from a dear friend. Unfortunately the large black rubber band has broken at the hole that I regularly use...
mcdevito75 Here, You may be able to find a replacement band on ebay, or look for a small watch repair shop in your area for a replacement or repair, the band may be able to be glued.
Jul 09, 2010 | LogoArt St. Louis Cardinals Wrist Watch
I have a sector 600 series with a black rubber strap-band and the band broke two montha go, and i still can find the band-strap for my sector
Here you will find Sector contact details:
And here is the link where you can find nearest Sector:
You have to contact them and ask for the strap/bracelet you are after.
Rate me, please.
Aug 14, 2009 | Sector 2653940025 Wrist Watch
Missing piece to Luminox 3000 black rubber watch band`
Try they can get the part or a substitute part, the keeper is not sold separately tho, you would have to buy a complete band...good luck :)
Mar 18, 2009 | Luminox Navy Seal Dive 3001 Wrist Watch
La Crosse K2-100 Wrist Watch Logo
Top La Crosse Watches Experts
Arturs Kalnins
Arturs Kalnins
Starnley Johnwells
Starnley Johnwells
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
