Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine shows 'dL F' even after unplugging.
  • 283 Answers
Do you mean "F dl"? That's a problem with the door lock - it tries to lock the door but for some reason (usually mechanical) it can't. Try closing it a little firmer. Sometimes the mechanism needs an extra push to get it to throw from one mode to another. If that doesn't help replace the latch mechanism. if that doesn't work replace the CCU assembly.
Posted on Jan 07, 2008
IFB washing machine showing dl er...what can I do ?
Mar 20, 2017 | IFB Washing Machines
WHIRLPOOL CABRIO DL ERROR
The DL is a door lock error but it can also mean an error with communication to the main control board o
First try to unplug all your connections to the main control board and plug them back in and try it again.
Sometimes a wire harness just may be loose.
If that does not work.
You need to replace main control board .
SAM ANDERSON
Sep 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/dL error code on...
The F/dL is shown on the display due to Door Lock Error in the washing machine.
In this problem check the Door Lock in the washing machine. Either the door is getting blocked or not getting locked or the door latch assembly is got cracked.it needs to be checked and replaced.
This will help. Good Luck.
on Mar 11, 2010 | Washing Machines
My washing machine is just washing draining but not spinning
1) door inlocked when washer is running, read your troubleshooting section and proceed according . or call customer service and get assistance via online chat.
God bless you
Jun 21, 2012 | Samsung Washing Machines
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
Washer show code dL
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!
Apr 14, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I am getting a dl w/an f error
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
-> Door lid is not closed completely due to interference.
-> Wash media buildup is preventing the lock bolt from extending.
-> Machine/motor control detects open door lid switch when attempting to lock.
-> Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 19, 2009 | Kenmore Elite 45986 Front Load Washer
I am getting an DL F code on my front loader
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
What do I do for dL and F error message?
same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
Jul 17, 2008 | Kenmore Elite 45986 Front Load Washer
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Dec 14, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
