Question about Texas Instruments TI-84 Plus Calculator
Will not respond at all@=!
My calculator could be turned on, but otherwise useless - no buttons could be pressed so the screen remained frozen. I tried changing the batteries but it would not work. This case happened to me before and I tried "bending" the calculator, which worked. But not now. Please help, I have an exam coming up!
  • 2 more comments
  • Anonymous Jan 10, 2008
    TI-84 Silver Edition-buttons row: LN, 4, 5 ,6 and - is not responding all other buttons are working.
  • Anonymous Mar 03, 2008
    I used an application and afterwards it froze my screen up. Does anyone know what to do?
  • dpriem2 Aug 25, 2008
    My calculator turns on, numbers are displayed from my previous work on it, the cursor blinks like it normally would but none of the buttons work or respond at all with the exception of the on button initially. I have to take the batteries out to turn it off. What can I do?
  • liangh003 Oct 22, 2008
    Not responding at all! Keys, screen frozen, cannot even turn off. Not batteries.
  • 9 Answers
I actually fixed mine!!!! The same thing happened to me. I found somewhere that the no/slow key response could be due to a short in the I/O socket. I blew into it really hard, (you may want to used compressed air, but I didn't have any onhand) and it works perfectly now!!!!!!! I hope this helps.
Posted on Sep 09, 2008
Mine turns on but no other keys respond so I can't try any of the suggestions. Is there some way to do a hard boot and start from scratch??
Posted on Aug 27, 2008
If no keys are responding, make sure that none of them are physically stuck in the 'pushed down' position.
Posted on Apr 16, 2008
Your ram might be full
2nd- mem(+) - mem mgmt/Del -
then either delete a program w/ delete key
or send an unstarred program to archive w/ enter key
Posted on Feb 13, 2008
I have the same problem. I can open it, but everything freezes. It's hard to do anything on it. I even sent it back and they gave me a "new one." But, it has the same problems as before. It's new, so theres enough ram. Solutions? Thank You for reading.
Same prob
turns on
As butt'ns arn't workin can not do
any other ideas.
Posted on Feb 22, 2008
Ti-83 won't turn on
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If the screen remains blank then please respond to this post and we'll go from there.
Jan 28, 2014 | Texas Instruments TI-83 Plus Calculator
TI-89 Screen not Responding
Remove one of the AAA batteries.
Press and hold CLEAR while reinstalling the AAA battery.
Continue holding CLEAR button and press ON.
Release buttons and press CLEAR again.
Jan 29, 2013 | Texas Instruments TI-89 Calculator
Calculator not turning on
TI calculators have an annoying habit of dimming the screen when the batteries are changed so as to appear not to be turning on. Turn the calculator on (or at least press the ON button). Press and release the 2nd button, then press and release the up-arrow button. Repeat the process several times and see whether the screen darkens.
Sep 25, 2012 | Texas Instruments TI-86 Calculator
I have a TI-84 plus silver edition. there was a notice on my screen saying that batteries were low. I replaced them, and when I turned it back on, the RAM was cleared, but the screen acted like it was...
If that isn't it, then remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries and turn the calculator on. (You may have to adjust the contrast as described above.)
Aug 31, 2010 | Texas Instruments TI-84 Plus Silver...
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
My TI-84 Plus calculator won't work. It won't switch off by itself. When the batteries are reinserted, it says that all RAM has been cleared. When i press the 'ON' button again, the screen clears. but...
The Ram cleared message is normal after you change batteries. When you see this message you press the CLEAR button to erase it. You do not press the ON button again because the calculator is already ON. If you want to turn calculator OFF you press [2nd][ON] (OFF).
On certain calculators, pressing the ON button when calculator is already ON is interpreted as INTERRUPT the current command.
Jan 04, 2010 | Texas Instruments TI-84 Plus Calculator
All buttons on my TI 84 are frozen
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Nov 01, 2009 | Texas Instruments TI-84 Plus Silver...
Screen frozen
When you turn the machine down, it rests where you left it, in the state you left it: In case you wanted to continue with the same program, what you have already accomplished will not be lost.
After you turn it on, Press [2nd][QUIT] or just press the [HOME] button, and it will take you home.
Hope it helps
Jun 15, 2009 | Texas Instruments TI-89 Calculator
Ipod touch 8 gb. The screen is frozen
You must attempt to refresh your iPod Touch.
Hold the Sleep Button and the Home Button at the same time for 10 seconds. The screen turns off, wait for 5 seconds. Then hold the power button again until you see the Apple Logo. Wait for couple of seconds. Then your problem should resolved!
If this does not work, let me know. :).
Mar 20, 2009 | Apple iPod touch
Screen frozen calculator not responding to buttons pressed.
give it a factory reset, this works, you will lose any unarchived data : http://www.associatedcontent.com/video/265/how_to_reset_a_texas_instruments_ti89.html?cat=59
Aug 30, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-84 Plus Calculator Logo
792 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
