Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool Side By Side GD5RHAXNQ00-Electrical Issue
Fridge light is not working. The temperature control LEDs are not working.I replaced the lightbulb and there is a very small glow on the filament. There is an electrical "arcing" noise coming from a white relay box in the back of the Fridge–only when the Fridge side door is opened. The unit is staying cool.  Do I need to call for service or can I fix?
  • 2 more comments
  • ted1998 Jan 12, 2008
    Have similar problem. Have not noticed an arcing noise, but did when light went out.
  • idglenn Aug 03, 2008
    I have the same problem, but all wires and connections look good. It seems to be an easy fix, but what else can cause this?
  • claytonmorga Aug 12, 2008
    I have the same problem, but no arcing. Will the LED's go out just because the regular bulb went out? I first thought that it was the door switch, tested it and it's fine.
  • ceptap Oct 02, 2008
    whirlpool gold side by side , lights don"t work . heared poof sound . i took back carboard off then followed yellow with red strip on it from the switch. it went to circuct board on bottom left side.it goes to a harness into the board. could it have just blowen a resistor to the lights, or should i install new board?
    Sergeant:
  • 288 Answers
The arcing noise is just that, a loose connection causing electricity to arc from one place to another. this is initiated by opening the door and closing the light switch. The small glow is from a small amount of voltage reaching the bulb. If you are inclined, repair it. remove the cover, look for the burnt wire or connection. If its a removable part, replace it. If not clean it up and/or make a new connection. One thing is for sure, it will not get any better and may get worse and burn up something more critical.
Posted on Jan 13, 2008
Gd5rhaxnq00
The lights are controlled by door switches and a small circuit board near the compressor=> W10135090 Main Control Board
The control board is quite expensive and if you know someone that can replace circuit board parts it would really pay to have them replace a defective relay, Thanks Sea Breeze
Jan 30, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
GD5RHAXNQ00 LEAKING?
There are several causis from water leaking from the back of the fridge did you check is not condensation? In case you will need to lower fridge temperature
Feb 24, 2008 | Whirlpool GS6NBEXR Side by Side...
HAVE A GE PROFILE SIDE-BY-SIDE REFRIGERATOR ABOUT 10 YEARS OLD THAT NEEDS A GARAGE REFRIGERATOR KIT INSTALLED. IN MY UNHEATED GARAGE AND NOT WORKING IN FREEZING TEMPERATURES. TRIED A 100w LIGHTBULB...
You need to put a heat source in the fridge compartment near the fridge thermostat. Try putting a lower wattage bulb (40w) into the fridge compartment. Or even try this, take the door switch out of the fridge and short the two leads together. Tape the exposed ends with electrical tape and that should provide enough heat to keep your compressor on long enough to keep the freezer cold. Just remember to put the switch back in in the spring and summer months or you will have a real high electrical bill. Hope this helps you.
Dec 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool model HAXNQ : lights out on fridge side only
Hummm... I would suspect your DOOR SWITCH on the fridge side... $11.321 shipped... eBay!
Anthony
Whirlpool 1118894 Door Switch
Dec 02, 2017 | Whirlpool GS5SHAXN Side by Side...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL SIDE BY SIDE MODEL GD5RHAXNQ00 ELECTRICAL ISSUE
most comonly the door switch has blown. if you are not using the humid switch in the on position . condensation can build aroud doors and consiquence water gets into the switch. youll nead to unplug the unit and pull out the switch carefully not to damage the breaker strips use and olm meater to check the switch for condinuity.
Oct 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GD5RHAXNQ00 Ice maker not making ice
We had a similar problem and there was a broken/stripped gear in the icemaker. A&E replaced it to the tune of $150 or so. I don't recall exactly but I recall my husband thinking he could replace the entire icemaker for the price we paid to repair it. The gear make the ice tray flip out the ice once frozen. Good luck, hope that helps a little.
Jun 21, 2008 | Whirlpool GD5SHAX Side by Side...
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lights out in the fridge side only
yes, and it should be covered under warranty. whirlpool has experienced problems with interference on this model . could have taken out one or both of these. control 2303805, and 2304056. tech must also install a ferrite insulator on control to filter interference and move the water valve wiring away from all other wires. use this info to get it fixed under warranty.
Jan 31, 2008 | Whirlpool GS5SHAXN Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
217 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
