Question about Bosch Axxis WFL 2060 Front Load Washer
Won't spin - belt fine!
The motor sounds like its running but not spinning - belt is OK pulley's are OK.
what to check next????
  • Anonymous Mar 01, 2008
I had the same problem with my Bosch 2060, which is almost 6yrs old. After opening the back of the washer and inspecting, belt looked good and not loose. Spending several hrs on net looking for postings, most thinking replacement of motor brushes is the solution. Someone posted that the connector on the right side of motor (located under the tub) to the right side could be loose. I pushed on the connector to make sure it was tight. Powered up and went to spin cycle and was greatly relieved that washer began to spin. Thanks for whoever posted this simple fix.
Posted on Jan 31, 2008
Remove black drane hose between tub and pump and look for/remove kids toys, money, or any other small objects that prevent pump from closing to triger, the spin. I just found this out. if the pump think it still has water to pump out, it wount kick out and go to the step, hench no spin.
Posted on May 23, 2008
    Master:
  • 619 Answers
Replace the capacitor dried or open.
Posted on Jan 07, 2008
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
Drum won't move
take the back panel off make sure power is off and check if the belt has come off or broken and also check the pulley that spins belt is tight and if all that is ok then it sounds like the motor might need to be looked at
Jul 05, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Washer spins on delicate only. Won't spin on
Hello, Does it sound like its spinning in regular and just not spinning? If So You may just need to replace the belt. Also this unit the motor pulley would melt and break. Lean the unit back and you can see the belt and pulley. Hope this helps and please dont forget to rate me. Thank You...
Jun 08, 2011 | Maytag Atlantis MAV7551 Top Load Washer
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
My washing machine will not spin...
As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Feb 10, 2010 | Washing Machines
Washer motor spins but not the belt in spin cycle only,
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine wont spin in spin cycle ,makes spinning sound just wont spin
Jan 01, 2010 | Washing Machines
New belt runs too close to drum on pully
adj belt in motor pulley groves 1 grove at at time spin with hand to center on drum pulley
Dec 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
157 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
