Setting up linksys wrt54gs
Hi put the password in as it says in the book but it is not working can you help thanks kev
  • 62 Answers
I would suggest trying to connect without encryption first. To do this you will need to reset your router to it's "out of the box" state.
You can do this by pressing the small reset button on the back of the router for 30 seconds.
Remember when you do this all of the routers configuration settings will be set back to the default. This means that the name of your wireless networksetting up linksys wrt54gs - 1.gif will change back to "linksys". Also resetting the box can cause a conflict with certain DSL modems that assign IP addresses from the same subnet as your router.
Let me know if you can connect to the internet wirelessly after performing these steps.
Posted on Jan 07, 2008
Set ssid for wrt54gs
You do that in the router setup an SSID is simply a "Name" that You give it. You log into the router, 192.168.1.1 use admin/blank and admin as login & password..once in the router you set it up with the wizard.
here is a manual to help you.
http://www.retrevo.com/support/Linksys-WRT54GS-Wireless-Routers-manual/id/421ci076/t/2/
Feb 23, 2010 | Linksys WRT54GS Wireless Broadband Router...
Linksys WRT54GS
No, you should however, log into your Linksys's admin page and copy your settings down. Put those back into your Netgear and you should be good to go.
Feb 15, 2009 | Linksys Wireless-G WRT54GS Router...
I put the password admin on my linksys model n. WRT54GS and after it checks my computer settings and its always asking for it
For linksys router by default there's no username and password is admin, and if that is not working try some of your commonly use password and see if that will work, if still no password is working the only to correct everything is to reset the router by pressing the reset button of the router for 10 seconds using a pen while power is ON and then after resettnmg password will be back to admin so you can reconfigure it back...
Dec 09, 2008 | Linksys Wireless-G WRT54GS Router...
Password problems with linksys router model n.WRT54GS
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
I cannot set up my Linksys wireless router model number:WRT54GS to work properly. I have a desktop computer with Windows XP operating sysyem. I have three other laptop computers with wireless components
The easiest would be to connect your desktop straight to your modem and verify that you can connect to the Internet. Do not use the LinkSys WRT54GS yet. Pop in the CD that came with the WiFi Router and run the setup wizard. Follow exactly on screen instructions. Verify that your desktop's networking is set to auto obtain IP address.
Alternately, you can try:
1. connect your desktop with a straight through LAN cable to Ethernet Port #1 of the WRT54GS;
2. set your desktop to use IP-192.168.1.10, Subnet Mask-255.255.255.0, Default Gateway-192.168.1.1;
3. open a browser and goto 192.168.1.1. use the LinkSys supplied username and password;
4. verify/configure/set the LinkSys to your preference;
5. for the time being do not use any security keyphrase, WEP WPA or MAC filter;
6. verify that your laptops could see the router's SSID;
7. verify that all laptops are set to auto obtain IP addresses;
If for some reason neither method will not work, pls post back with your modem's make & model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 07, 2008 | Computers & Internet
WRT54GS version 6
Go to the linksys website at www.linksys.com, select your router, and you should find a link offering a driver download.
Apr 08, 2008 | Linksys Wireless-G WRT54GS Router...
You just needed to Connect ur router to the computer
1>open Internet explorer type 192.168.1.1 and then Enter
2>Leave the username blank and password admin(lowercase)
3>then in linksys page change the Local IP of the router to 192.168.2.1 and then power cycle the network it will not create any problem later
Mar 08, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS not detected
I am having the same problem with the WRT54XG4 but i discovered that if you disconect the internet port of your router and leave the ethernet port conected to your computer. You can access to the router and you can upgraded.
Hope it help you
bye
Feb 24, 2008 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
182 people viewed this question
Alun Cox
David Payne
David Payne
