Question about Kenmore 63942 Dryer
Electric whirlpool dryer has no heat
This dryer is not that old only had it about 4yrs, do you thisnk this is the heating coil already?
  • Anonymous Dec 11, 2008
    my dryer will run, but there is not heat and the timer will not turn, so the dryer just continues to run until i manually stop it? what do you think is the problem?
  • 90 Answers
Most likely a thermal fuse on heater housing
Posted on Jan 08, 2008
I have a Westinghouse Sensordry LD505E Dryer which has suddenly stopped heating up
Either your dryer vent is clogged or your heating element / ignition coil has failed. It's called a hot surface igniter
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_677dced97ad9bddf
May 19, 2014 | Heating & Cooling
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
My Whirlpool Imperial electric dryer runs but there is no heat. I changed thermal fuse already.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer not heating, everything else is working fine.  Already tried heating coil replacement.  I think that was unnecessary.  Am looking for the fuses but don't know where to look.  Also...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
45g
Jan 25, 2010 | Whirlpool LER4634J Electric Dryer
I have a less than one year old whirlpool dryer, model number WED6600VWD. The drum works and it does have power. However, it does not generate any heat, like the heating unit isn't working. What might be...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 06, 2009 | Whirlpool WED6600V Electric Dryer
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer wont heat up already replaced thermal fuse
You gas coils are probably old and weak. check this out
Gas dryer works and quits
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 11, 2009 | Whirlpool Dryers
Whirlpool dryer works fine but is not heating
If this is a gas unit the igniter - may be cracked or burned out!
Electric the coil or element is burned out
Mar 27, 2009 | Whirlpool LER5636P Electric Dryer
No heat Whirlpool dryer
when you turn on the dryer does the ignitor glow if it does replace the coils if not check the thermal fuse
Dec 19, 2008 | Dryers
Kenmore 63942 Dryer Logo
124 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
