Question about Kenmore 45081 Front Load Washer / Dryer
Kenmore model 41743142200
I have a front load kenmore that won't spin. It stopped working and I found that the belt had fallen off, after replacing it, now I find that washer does everything but spin. During the spin cycle it acts as if it's in wash cycle (it spins several times in one direction then stops and repeats in the other direction until cycle ends).
  • 619 Answers
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Posted on Jan 07, 2008
Hello, My Kenmore Model #11042822203 Front load washer stops after water goes into the drum. It makes a straining noise. It spun last time I tried it, but went slower than normal.
This could be a lot of things. There is a belt drive on the drum, The belt might be worn out, there could be a bearing that is starting to fail or it could be the motor or motor control board. Kenmore Washer Won Spin
Jul 08, 2017 | Kenmore Washing Machines
Replace washer spin basket kenmore elite 110
sounds like a bad bearing on the rear of the tub. If you remove the rear access panel you will see a large pulley and belt. That attaches to the inner drum (basket) and spins it. It floats on a bearing just behind the pulley. If the bearing is bad then you will be able to move it up and down about .25 to.50 of an inch.
Jun 25, 2014 | Kenmore Elite 45986 Front Load Washer
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
Washer will not spin. it will fill then immediatly empty,3 time no spin or wash. belt is on, motor spins freely, the timer does move with cycle but fast kenmore 41743142200
this sounds like a timer problem, but need the make and model number to be sure, this model number will be on a on the rear panel of washer, or with the original owners manual.
Aug 17, 2010 | Washing Machines
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Replacing shocks on front load washer
through the lower door panel in front of machine. Why???? is machine walking , bouncing or other wise?? This machine spins at HIGH Rpm's so most usual problem is one leg maybe unlevel or possible wood floor maybe "giving " as machine spins and allowing the machine to walk...but then again if machine is "old" shocks could be worn out
May 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 45081 Front Load Washer / Dryer Logo
356 people viewed this question
Sal De
 Brian Main
Brian Main
