Question about GE Spectra JBP78 Electric Kitchen Range
GE Spectra range
The clock, timer, and stove light work.
All 4 glass burners, oven, and broiler will not turn on.
The surface hot light comes on but nothing heats up.
I turned the circuit breaker off for 20 sec and still nothing is functioning but the clock, timer, stove light, and surface hot light.
  • 2 more comments
  • sebbyg Apr 04, 2008
    I have the same problem how did you resolve it.
  • Anonymous Jul 03, 2008
    Having the same problem.  When the back metal cover was removed it turned out that one of the wires was completely melted in half.  Working on locating a new cord, although it makes me a bit nervous.
  • Anonymous Apr 23, 2009
    same problem but with electric range
  • Anonymous Mar 31, 2014
    hot point range stove on light wont turn off
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
  • 23 Answers
All of the items you mention that do work, are 120 volt items.
All the items that do NOT work are 220 volt items.
Sounds like you have a voltage problem, you will need to use a meter to check if you have 220 volts a/c to the outlet the stove plugs into. Take care when doing the following, you will be around live voltage and could get hurt. If you are uncomfortable working with a live circuit best to call someone in to do it for you. Check for 220v at the outlet for the stove (where the stove plugs into), if you have it there, go to where the cord attaches to the stove and check at that point. You should have either a 3 or 4 wire cord on the stove, On the rear of the stove there is a terminal block that the cord is fastened to. Between RED and BLACK you should have 220v, between RED and WHITE and BLACK and WHITE you should see 120v. Another thing to check is that the nuts holding the wires from the cord to the terminal block on the stove are turned down tight. A loose connection there will give you the same problem you have as well.
Posted on Feb 19, 2008
Oven doesn't work - broiler, clock timer does
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 05, 2010 | GE Profile Spectra JGBP79 Gas Kitchen...
Ge spectra eterna series gas stove broiler will not fire up. The glow plug gets hot, but the broiler fails to start.
I have an GE Spectra Eterna Series where the oven comes on and only gets warms no matter what setting the oven is set at. Can some one solve this problem?
Mar 07, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
I have a GE Model JGBP265BEA1WH and the oven would not work. The broiler & stove top did. I replaced the ignitor and now both the oven and broiler do not work but the burners do. I tried to locate the...
The burners and its components are totally seperate from oven and there is no controlling shared between them. The problem can be many. Can be the timer control that is locked and not allowing any oven functions. Can be the electricline feeding the oven portion. Can be the oven temp control that tells bake and broil to begin functioning. Can be oven lockout. This is a function that you can turn off by holding the clock or other pad button for 3 seconds. Check your manual to see if I am correct about which touch pad to hold. This is a safety feature that sometimes gets activated and there's no flashing lights telling you about it. Goodluck<Macgivor
Jan 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
2002 GE XL44 converting from LP to Nat Gas
the jet sizes will have to be changed due to the weights of different gasses
Jan 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Bake and Broiler do not work
it sounds like you have a bad eoc which is electronic oven control that is the only thing it could be if your top burners are open
Dec 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Jun 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
918 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
