Question about Sharp XR-10X Multimedia Projector
Input 1 We use this unit at our Church and the following thing happens: Using the remote control whenever pushing the Input 1 button nothinh happens. You can use the manual button and it will work but if you shut the computer down you have to go through the same process of doing this manually. Any suggestions would greatly be appreciated. Thanks, Kenny McDaniel (404) 346-5815 ext 285
  • Muttenjaws Jan 07, 2008
    It only does this on input 1 and input 2
    Thank for you help
  • 579 Answers
We have a similar problem with our sharp projector at church where the remote is on a long cable up to the projector as it is too far for the infrared. Sometimes it quits listening to the remote and we've found that unpluging the remote cable and plugging it back in restores the operation. Apparently, the long cable introduces noise into the remote input and gives it illegal codes sometimes.
Does yours only do this with that one button?
Hope Ya Fix it! Grace and Peace to you....
Posted on Jan 07, 2008
How to remove code set 3 for the remote control panasonic bd-45
It seems the best way to "remove code set" is to overwrite it with a different code set.
(From the Owner's manual for the Panasonic DMP-BD45)
STEP 6 :
Reprogramming the remote control
Change "Remote Control Code" (-> 28) on the main unit and
the remote control (the two must match) if you place other
Panasonic products close together and it responds to this
remote control.
You can operate the TV or amplifier/receiver using the unit's
remote control.
1 For televisions
Input the code (-> 37) with the numbered
buttons while pressing [? TV POWER].
For amplifiers/receivers
Input the code (->37) with the numbered
[RECEIVER j VOL].
e.g., 0001: [0] -> [0] ->[0] -> [1]
2 Test by turning on the television or
adjusting the volume of the amplifier/
receiver.
Feb 20, 2016 | Panasonic Televison & Video
I accidentally changed the settings on my remote control using the on screen menu from dvd1 to dvd2
I'm not sure the question - perhaps your TV is set to the DVD2 input and it's not a DVD issue.
If so, using your TV remote, push the "input" button until you reach your desired input.
Apr 07, 2015 | Televison & Video
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
CODE FOR TDE SYSTEMS UNIVERSAL REMOTE CONTROL
CANNOT PROGRAM THE TDE SYSTEN=MS JUMBO REMOTE WITH CODES FOR A CITIZEN TV
Mar 01, 2009 | Universal Televison & Video
Bose 3.2.1 GS II region free
TRY THIS Multi-Region:
1. Using the remote control, key in the following: 9, 4, Shuffle, Stop, Mute.
To set a specific region:
1. Using the remote control, key in the following: Open (to open the tray - if already open, no need to press it), Stop, Shuffle, followed by the region number.
2. Press the Enter button on your remote control.
Jun 07, 2008 | Bose 3·2·1 II System
Can't watch dvds with my dvd player
Try two different things 1) on some of these tv's you could try pressing 00 to see if it will put you in input mode or 2) with your remote you should be able to push the input or tv/video to go to the input selection . In both of the above make sure you push the tv button first then step 1 or 2 . Good luck
Mar 07, 2008 | Proscan PS27108 TV
GE RM24948 Code input prob
1. Ch (-) x #
2. Vol (-) x #
3. Ch (+) x #
4. Vol (+) x #
Hope that helps. Same thing happened with me and it took a while to figure it out. like 20 min. to try all combinations with all different codes.
Oct 09, 2007 | GE RM24948 Remote Control
Sharp XR-10X Multimedia Projector Logo
132 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
