I have a DEll Inspiron 630m. My screen has been going a bit wierd of late, every now and then it used to go all pixellated and i would have to reset. Then i realised that if i put my thumb in the corner of the screen it would go back to normal. In the past few days it has done it almost non stop and each time i pressed on the screen or sides of the screen it would go normal. At present i have 2 clothes pegs on the side panels of the screen and everything is fine. Does anyone have a clue as to what is happening and how much or how hard is a fix?
Try connecting the laptop to an external monitor then use it check if you will be getting same problem while using external monitor. If not then LCD Panel, LCD cable and LCD inverter on your laptop needs replacement.
I have a aspire one netbook model no. kav60. I have both the pxe-e63 and pxe-m0f errors display when...
(More)
I have a aspire one netbook model no. kav60. I have both the pxe-e63 and pxe-m0f errors display when i first boot up. when i go to the device manager it is showing the ethernet controller and network controller drivers are missing. i assume this is related to my inability to connect to the internet. please, what is going on?! how can i fix this?! any/all help is appreciated... thanks
master cd/dvd does not reboot to factory settings stating i got wrong disc got error message, need...
(More)
master cd/dvd does not reboot to factory settings stating i got wrong disc got error message, need to reinstall but how?
