Question about Lexmark Office Equipment & Supplies
My printer has had a new hard drive fitted and i cant reconnect my printer i have a disc but it comes up with a message cant find server but at the start it comes up with new hardware found ready to use but if you try it it says you have to install a printer i am not to bright with tech.problems thanks pat
J ai acheter une imprimante lexmark x3350 et je ne peut pas finir l instalation car il y a un vérus qui est sur le cd
Posted on Feb 04, 2008
Hi experts, I have scoured the internet and I have not found anyone who is in the same situation as I am. I just bought this laptop by HP "hp envy touchsmart m6-k022dx sleekbook" to replace my previous...
if you want a hard drive that will not fail the hard drive should be a solid state (SSHD)
they are priced at around $60.00 a gig and come in sizes from 120 to well over 500 gig
as there are no spinning discs, failure is remote
besides that a sshd will store more for the same gig size than a disc HD
now best talk with a computer geek to get exact information but you should be able to remove the hd in the computer and replace it with a new one
now connect the hard drive ( removed ) back to the unit as you would a backup hard drive and then down load it back into the computer
remember when fitting a new hard drive you may have to reset the bios to boot from the cd os disc or boot from the removed hard drive as the new hd will not have an os on it
AS I said talk with a geek and get how to do it
computer capacity is also determined by the ram size so if you have the slots fit another ram stick
Mar 02, 2017 | Computers & Internet
Lexmark 7170 all in one scanner not working - printer and copier is working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If you're scanning documents for editing, make sure that the Lexmark OCR scan software is installed on your computer. The OCR scan software is only available on the installation disc that came with your printer (no downloadable version). If you have the disc, simply insert the disc into your computer hard drive and execute the file.
Dec 22, 2011 | Office Equipment & Supplies
I can not scan documents with Lexmark 2500 Series via Windows
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Disconnect the printer from your computer. Reboot your pc. Unplug the re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Also, make sure the Lexmark OCR scan software is installed on your computer. The scan software is available only on the install disc. Insert the cd in your hard drive to install the software. If you lost the disc, please contact Lexmark technical support for additional assistance.
Jun 17, 2011 | Lexmark X2500 All-In-One Printer
I need printer repair for an HP Laserjet 4250n. I believe I have some gears that may need replaced
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | HP LaserJet 4250n Printer
No printer software
i pretty sure the printer you talking about is a dell here is the driver site
Aug 11, 2009 | Dell 926 All-In-One InkJet Printer
Western digital Scorpio 120 G
Actually there is no solution, the hard drive is bad.
What I ended doing was recording the partition in iso. ( I had a Factory Partition)
Got a new hard drive 160G scorpio unfortunately it does not come with installation disc.
Installed Vista, and with vista created a partition and then installed the contents of the factory partition.
Feb 18, 2009 | Western Digital Scorpio WD1200BEVS 120 GB...
On start up message 'disc failure 19.1' comes on.
POST Error Code of: 19.01 Flutter and then 19 blinks
Check and reseat hard drive cables. Replace hard drive, if necessary.
Hard Drive Part Number is: 121K39240,Printer,Part,121K39241.aspx
You can also contact a local Xerox Authorized Service Partner to see if they will sell you the part.
Nov 27, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
How to download unreadable disc for lexmark printer
The printer install disc may be faulty or your disc drive is faulty.
Insert the disc into a different computer, if it can be read then the problem is your disc drive.
If it is your disc drive, turn off your computer, open your computer and remove and reconnect the power and data cables on the "faulty" drive, switch on your computer, let it boot up and install the printer disc.
If it still cannot read the disc then you need to replace the faulty disc drive with a new one.
Sep 24, 2008 | Lexmark Office Equipment & Supplies
Maxtor OneTouch lll Mini 120 GB
If your using a USB hub, unplug another device (i.e printer or scanner, fax, etc.). Plug in your One Touch. Then turn off your pc and turn it back on. This should work.
If you use a alot of USB devices, you may need to get a USB Power Hub.
You can try an plug in the One Touch straight to the pc and unpluging all other usb device except the keyboard and mouse.
Let me know if this helps. You also may need to move the ac power to another outlet.
Sep 01, 2008 | Maxtor OneTouch III Mini Edition 120GB...
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
