Oki es 3640 error 588
Cover needsejecting.all the covers are closed .
  • Anonymous Oct 01, 2008
    OKI ES 364 IS IT SAME AS OKI ES 3640
    PLEASE LET ME KNOW BEFORE I BUY ONE
    REGARDS
    TOM
Soulvisitor
  • 1113 Answers
SOURCE: brother laser mcf-8440/ machin error 7a
and brother would say...7a= Main motor does not synchronize with the reference clock, .... check.....
• Thermistor ASSY
• Main PCB
• Engine PCB
• Main motor
and fix i'd say is to replace main board.
Posted on Nov 09, 2007
  • 5 Answers
SOURCE: my mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Posted on Dec 18, 2008
  • 6 Answers
SOURCE: Error: "Back cover is open. Close back cover."
We had this problem. It turned out there was actually a piece of paper stuck in the printer! It wasn't so easy to see it from the rear.
We removed the paper from the front by taking out the ink cartridge first. Turned the printer back on and everything was fine.
Posted on Apr 06, 2009
brett207
  • 231 Answers
SOURCE: the error message says Doc. Cover open but the
You will probably have a broken hinge at the back left hand side of the Doc. cover.
This means that the cover won't close properly at the back corner, and the cover sensing switch won't actuate.
Posted on Dec 08, 2009
SOURCE: cover open pls close cover error machine 71
DCP-1400 HAS ERROR MESSAGE "MACHINE ERROR 71" HOW DO I CORRECT THIS?
Posted on Jan 01, 2010
What does error message 'CLOSE UPPER COVER' indicate?
The printer may be unable to sense that the upper cover is closed when, in fact, it is.
Jan 04, 2016 | Oki Electric Industry MB460...
In my OKI c301dn cover open, but it isn't
when cover open in oki c 301 dn then push pull switch is UN link and information show cover open in printers or copiers. just change push pull switch or clean that with ctc the switch you can search on casing were the cover is close and can push that.
Jun 03, 2015 | OKI Office Equipment & Supplies
OKI b410d error 382
That is a paper jam code. Reopen the cover, and clear all paper jams. Close the cover, and then I would reset the machine by turning it off and on if the code continues. http://www.german-parts.de/oki_manual/paperjam/stau_b400_series.pdf
Feb 05, 2015 | OKI B Office Equipment & Supplies
Oki b431d paper jam
Paper jam is initiated by a sensor that does not register (or tell the logic board it has registered) a movement of the paper through the printer. Try finding out what sensor is near the point the paper stopped. Look if anything id blocking a optical sensor, or any small lever is blocked in free movement. Close all covers correct and make sure nothing is blocking the covers. Not even just a small piece of paper.
Jul 16, 2014 | Oki Electric Industry B431d Printer
I have no Oki, i have Intec CP2020 and I see that they are pretty much the same printer. So, I have problem service call:175 fatal error, it says. Any ideas? Thanx
i have intec cp2020 machine showing error code close the frond cover error code 330.already closing frond cover.what is the problem machne i will wait for replay.i will check the pwersupplay board & fuse
Nov 20, 2010 | OKI C9600n Led Printer
OKI error 310 and 311....
both are "cover open errors"
310 is top cover
311 is front cover
make sure both are closing properly.
Jun 18, 2010 | OKI C3400n Laser Printer
Dear Sir(s) I have an OKI data OL400e the problem is "Message --Cover open" even i close it well Please advice Thanks
had the same problem. It is easily fixed.
On my printer a OKI C5750 is had to main covers, at the front (which you have to open to fix a paper jam) and a big cover on top (which you need to open to replace toners).
On the left is a piece of plastic which (when closed) presses on a switch.
When you open both covers, and close the top one, you can see it on the left when it comes down.
You can easily remove the error (only for a brief moment) by prushing the shining metal switch to the back.
But the problem is that one of the rollers is in a wrong position.
So just take a flat screwdriver and press on the bottom roller, and it will click and the problem will be gone when you close the covers.
Feb 11, 2010 | OKI OL 400e Led Printer
Error message stats 'pull out trays clear jam, close cover A. but can't find any paper in machine and cover a is closed
a very usual problem steve. try removing power to the printer and let it stay idle without power for abt 20-30 minutes and then try again.this should clear the error message from the memory.
Feb 04, 2010 | OKI B6200 Laser Printer
Close cover 310: cover open, but it isn't
Nov 23, 2009 | OKI C3400n Laser Printer
Oki error 380
Ich denke es mus die Sensorplatine mit den drei Gabellichtschranken im manualtray ausgetauscht werden.
Nov 25, 2008 | OKI C9500dxn Led Printer
353 people viewed this question
k24674
jasbo
jasbo
