AEG Electrolux L74600
Hi, my father is working in germany and he sent me a new AEG L74600 washing machine but when i tried to make it work an error display of E60 was on the display and the machine is not working.
Please kindly advise what does it mean. I really need to make the washing machine work since the old washing machine is broken.
Hoping for your expert advice before i ran out of clothes.
regards,
Joey
  • Anonymous Feb 10, 2008
    what does E60 means ?
5 Suggested Answers
SOURCE: Electrolux EWF 1087 error code E60
user manual tells you what faults are
could be blocked inlet valve not filling in correct time or pump blocked
not draining in correct time
Posted on Mar 15, 2008
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
  • 3422 Answers
SOURCE: E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
Posted on Aug 06, 2008
Chesc
  • 59 Answers
SOURCE: we have a aeg electrolux
You may have had an overspill of water into the float chamber.
If you take the back off try removing the water that is actuating the float switch.
Then check if the float is working correctly.
Reset the machine and try again.
Make sure there are no leaks.
Hope this helps.. Good luck! :)
Posted on Jun 07, 2011
Aug 06, 2008 | AEG L74800 Front Load Washer
Washing Machine AEG Lavamat L64850 - cant change the washing time?
Not all of the options on the AEG Lavamat L64850 are available with every cycle. The Time-savings option isn't compatible with the 40-60 Mix program. See ManualsLib, https://www.manualslib.com/manual/555025/Aeg-Lavamat-L64850l-7kg.html?page=16#manual , for the various washing programmes and the available options.
You can get the full manual for your washer at AEG, https://www.aeg.co.uk/support/download-manuals/ . There are several models listed. The direct link to the manual for the L64850L/91452556002 is currently http://www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL=2013\132\950431EN.pdf .
I hope this helps.
Jun 14, 2018 | AEG Washing Machines
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
I received an error EH1 in my AEG electrolux Lavamat L64850l washing machine, how can solve it?
Problems with the electrical power supply, the appliance remains in the alarm state until achieve conditions of work, and stabilizes the voltage and frequency, and the machine resets quenching (controller to the position "0").
Obviously there is a problem in the electrical network so my suggestion is to call your local electrician or try connect power supply from any other room.
Dado
May 04, 2015 | AEG Washing Machines
We have a aeg electrolux 7465OLE washing machine for clothes. it is saying EFO and continues to make noise while off. what is it?? What dos EFO mean??
Jun 07, 2011 | Electrolux Washing Machines
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
Jun 04, 2010 | Washing Machines
Need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Apr 09, 2008 | Washing Machines
Open Questions:
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
