Piping TV throughout house
Can I install twin aerial outputs. in each room, and 'daisy chain'throughout my house with a single connection to the aerial to get reception in each room.(rather than having separate cables from each room into the loft) By doing so will the outlets act as splitters. Will this work wit digital signals
  • 579 Answers
Yes, this is done many times. If you do have a degraded picture because of all the slitters you can just add a antenna booster amp to compensate.
Posted on Jan 07, 2008
No tv channels found on autotune . Aerial is in Loft.
To get a 6 way or 4 way signal, it has to be amplified. Does your splitter have a power connection to it. If you just have one lead going into a block and 6 outlets, that is for a high gain signal to go in that is already amplified. You can test by disconnecting all the leads but one. Use the closest set to the loft and use that one to get the sharpest signal by turning the aerial left and right. It has to be in the right direction and if it is off by just two degrees, you will not get a picture. Also aerials and better situated outdoors for the best signal.
Jun 23, 2017 | Televison & Video
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
No dvb signal on Vierra Panasonic tv
If the tvs share the aerial but only one is working then the wiring of the non functioning socket has shorted. Perhaps the cable you used to connect the second set is damaged,try another. PERHAPS THE AERIAL SOCKET HAS BECOME DAMAGED,THIS ONLY COSTS A FEW PONDS/DOLLARS TO CHANGE. Alternatively it might be the wiring from the roof to the wall socket that is faulty.
First things first, check that the tv is working by connecting it in the other room. If it does work there you will know that theaerial socket in the second room is faulty and can begin testing.
Jun 03, 2015 | Panasonic Televison & Video
I cant view my sky channel on my tv
So you want to view your sky TV in a different room?
You can achieve this a number of ways.
Purchase the multi-room package from Sky TV. This will give you fully independent TV reception in each room. (Basically two sky boxes)
Purchase a TV sender which will wirelessly duplicate the output on the TV to another device.
Connect your Sky box to a second TV with high-quality co-axial aerial cable connected to the RF2 output on the back of the Sky box.
Mar 13, 2015 | Televison & Video
Twin dvi geforce 9600 gt 1gb - need installation instructions
ok well the soundcard is seperate - you can install it if you want but that would cut out room in the case as you have twin graphics cards going in... Main power lead to card should be an 8 pin connector - then they connect together using SLI joiner cable (joins the two cards together)
Minimum system power requirement is 400W Get your drivers from here Hope this helps
May 06, 2017 | Palit Microsystems GeForce 9600 GT, PCI...
Which speaker wires feed which speakers throughout my house?
Since this is a custom install and the wires don't follow a rule the only way to find which is which is to disconnect all the remaining speakers, plug in light bulbs in their places and check every single pair till they all match and their corresponding bulb lights up.
Dec 06, 2009 | Audio Players & Recorders
How do I connect my sky eye? It arrived with no instructions and I am not sure what i need to do! I have a sky box in one room and now the sky eye connected to my tv in the other room - does it plug onto...
You need an aerial connection between the two units,the aerial will plug into the eye and then the eye into the tv.The cable connects into your sky box in the one marked output 2.You then need to go into service`s on the sky box,select 4,then press 0 1 select,goto rf output and turn on.
Nov 11, 2009 | Televison & Video
Pay tv cable
you may bypass the box by using a straight connector, find the cable that lead to the TV room and connect it to the cable from the aerial antenna.
Mar 06, 2008 | Televison & Video
Unable to Tune TV to Sky + RF output
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
Jan 30, 2008 | Televison & Video
Daisy-Chaining a HomeLink Phoneline Network
With a HomeLink card installed in your PC, connect your PC to a phone jack using a standard phone cable. Using another standard phone cable, connect the card's other phone cable port to connect to your second PC. Continue to connect up to twenty-five PCs in this way on one chain. If you want to use your telephone, modem, or fax machine, add a two-way splitter to your wall?s phone jack or connect the device to the empty phone jack in the last card at the end of your daisy chain. Daisy-chaining your HomeLink PCs and peripherals can create a simple network that acts in the same way an Ethernet network acts on your PC's desktop. In a HomeLink network, data passes into one side of a port, and continues out from the port?s other side. You can string up to 25 PCs on a single HomeLink network, provided that the entire length of cable does not exceed 150 meters (500 feet). HomeLink networks can send data through existing telephone lines without disrupting your telephone service. If you have PCs on two different floors of your house, plug one of the downstairs PCs into the phone jack in the wall, and you're able to network your PCs upstairs without running excessive amounts of extra cable.
Feb 16, 2006 | Linksys HomeLink Phoneline (HPRO200)...
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
