Question about Ricoh Aficio 450 Copier
Richo 1045 sir how can i solve problems the laser unit of richo 1045 ?
  • Anonymous Jan 29, 2008
    sc 322 in 35 -45 cpm of ricoh
  • 162 Answers
Probably cleaning to the mirrors and glasses inside the laser the problem can be solved, but this is a complicated work if you are not technician I recommend to him that she asks for technical service. Also a bad connection of the flat cable can cause this problem. The detector of synchronism defective also since code SC326 is a fault of detection of synchronism.
Posted on Sep 15, 2009
Plz change the laser unit
Posted on May 27, 2011
  • 417 Answers
What seems to be the problem?
Posted on Jan 07, 2008
Richo 2045 paper misfed in C. I HAVE CHANGE THE PHOTOSENCOR AND THE PROBLEM STILL EXIST
i think you were cleaning the machine so when cleaning these type of machines you must be very careful.Okay you must change laser unit and don't blow these machines when cleaning because once the dust goes to laser unit it gives you a code/paper misfed so try to change laser unit
Sep 14, 2011 | Ricoh Aficio 2027 All-In-One Laser Printer
Witch is better Gestetner DSm745 or richo 1045 or richo 2045 any one help me pleas
dsm 745 has more modification than1045 more comfortable less disputes little problem. technicians can see this difference there are more details but i expressed that dsm 745 is recently than 1045 good luck
Jun 27, 2011 | Gestetner DSm745 Black and White Copier
In richo 1045, paper is contineus jam in the upper side of fixing unit
Clean oe change the upper fuser roller,fuser roller cleaning roller and clean the lower pressure(red) roller.
Jun 03, 2010 | Ricoh Aficio 450 Copier
Sir my Ricoh 1045 machine have SC 326 problem, after taking a single copy the error code comes. please give a good solution to clear my problem. thanks
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
Jun 02, 2010 | Ricoh Aficio 1035 Copier
EN UNA AFICIO 1045 APARECE SC320
Hello sir; That is laser motor defective ,just replace it, will be ok, it located left by the toner unit, behind the brown cover.
Dec 24, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1045 error e990 please help it
This is a software performance error; However it is most often caused by a deteriorating drum unit. There is no exact solution, but 9 times out of 10, a new drum unit, and fresh developer will solve it.
Outside of that, it is likely a board problem -possibly BICU
May 26, 2009 | Ricoh Aficio 1035 Copier
THE MACHINE KEEP ON DISPLAYING THE CODE SC0322 (COPIER RICOH AFICIO 1045 MODEL). HOW TO FIX THAT PLZ?
Ld unit problem. This code can be very frustrating, as it can be triggered by several things -top right door switches shorting out, toner on the LD unit board, laser synch board problem, bad connection between the BICU and the LD unit, etc.
The bottom line is, if you're not a technician, you will need one to solve this error.
Make sure to always perform the LD pitch adjustment (both 400 and 600dpi) after doing any service to the laser unit.
May 18, 2009 | Ricoh Aficio 1035 Copier
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error SC326 on aficio 1045
Hi there below is what is states in the service manual.
326 C 2nd laser synchronization error
The 2nd laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
• Poor connection between the laser
synchronization detector board and
the LD unit.
• Laser synchronization detector board
out of position
defective
• LD unit defective
Hope this helps you.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
237 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
