hey guys and gals ive got error 0102 and everything that ive found on the net has just told me its unkown, and vague posts saying cpu ram or gpu. can anyone here lend assistance? thanks, tristan
-   hi everyone,
i'm also experienced the 3 ROL sign with the error code of 0102. I have tried several suggestions like the eraser method, removal of the X-clamp with new heat sink compound and also the blanket method but noyhing works... please help///???-   jcct13
do the eraser trick http://uk.youtube.com/watch?v=3lldDG4SnAc then let it flash the rrod for 15-20 mins let it cool for a further 20 mins. the only thing different i did was to take the x clamp off the gpu, scrape the thermal putty off not all of it, just enough to cover the chips with then spread it evenly on the top of them with my finger put the x clamp back on put it back together with the erasers in and hey presto works like a dream. i had error code 0102
Was this helpful?
Yes
No
Solution #2
posted on Sep 11, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
mine had this error code 0102. after a little research i tried using a blow dryer on it it fixed it in like 2 or 3 minutes i'm guessing it has something to do with moisture
If you're comfortable enough opening your 360, you can try this tutorial, which has worked for many people.
Comments:
Jan 07, 2008
- Note: if your 360 is still under warranty, just send it in to Microsoft for repair as opening it up voids the warranty.
Jan 07, 2008
- You can also try the simpler, towel trick which has worked for many. It also seems like Microsoft might fix your 360 even if it's out of warranty, so it won't hurt to try to call Xbox support at 1-800-4-my-xbox.
The xbox starts up on its own and the tray opens. When it plays after a time the disk just opens and...
(More)
The xbox starts up on its own and the tray opens. When it plays after a time the disk just opens and the game shuts down
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
