Question about Magic Chef CTB1722 Top Freezer Refrigerator
New magnetic molding on refrigerator not working.....
I just replaced the molding on my Magic Chef refrigerator and the seal is not working. I have held a paper clip up to the molding to ensure that there is actually a magnet in there and it does have some pull to it. However, the seal is only good at the top of the door and about 1/4 of the way down the door. Do you think this is a bad molding? It's continually running now. Any ideas?
  • Anonymous Jun 25, 2008
    I just replaced my door gasket on my whirlpool refrigerator and the bottom of the door doesn't even come close to making contact. the top at opening fits well. we thought of shims to expand the door to meet the opening so the magnet will catch, we would need to get longer screws if we do that....any other suggestions. I am getting alot of condensation under my veggie bins.
    Thanks,
    Sharon
  • 283 Answers
Use a hairdryer all around the gasket to soften the vinyl then "twist" the door until you get a good fit. Leave the door shut and switch to "cool". Don't open the door until the gasket is at room temp. Tighten screws all around in random order. Repeat if necessary. In severe cases it might be necessary to "shim" the hinges out just a bit with cardboard.
Posted on Jan 08, 2008
Loosen the screws a bit and bend, to shape the flimsy door frame into a perfectly flat panel by opening and closing, and checking the fit and tightening gradually until it is true. This is not a fast job.
just putting a new one on does nothing without doing this.
I never replace seals unless they are absolutely needed.
6ya staff
SOURCE:
WHATs the equivalent of a door gasket for this magic chef refrig?
get the right one from the spares deaprtment of the service shop
There are people like "Door Seal" or fridge seal replacers who can make a seal on site to fit the door
May 12, 2015 | Magic Chef Refrigerators
WHATS THE PRICE OF COMPRESSOR RELAY FOR VISSANI HVWC28ST
I would recommed contacting the Magic Chef web site to order the right part. I did and it was well worth it and my replacement seal worked perfectly.
Jun 23, 2014 | Magic Chef MCBR440 Compact Refrigerator
I have a magic chef refrigerator model RB19KN3A serial no. DS37919804 . It was left with the house when I bought it. Wondering what year this model is and the molding around refrigerator is breaking away....
Yes, the molding can be replaced. All you need to do is provide your model number and make to www.repairclinic.com and they'll point you in the right direction.
Mar 09, 2011 | Refrigerators
I have a Magic Chef MCCF7 recently mold has been building up around the seal. the top when closed is very light and you can literally open it up with one finger. what can I do so I don't loose the food...
Use rubber gloves and wipe the seal with a cloth soaked in a diluted bleach solution (20 parts water to 1 part bleach). Let the seal dry. Chest freezers don't lose much of their cool when open so you won't have to worry about losing the food while you are working on it. Close the freezer and let it sit for 30 minutes then repeat the above steps until the mold is gone.
Feb 28, 2011 | Magic Chef 7 cu. ft. / 198 liter Chest...
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
Magic Chef MCBR1000W refrigerator section freezes things. Temp turned all of the way down. Bought used (as is) and regretting it. I want to make it work if cost effective. It was very dirty. There is a...
You made a bad choice. Will cost more to repair than to buy a replacement. You may never get the mold to stay away also. My advise get rid of it. Sorry.
Sep 29, 2017 | Frigidaire FRT17G4B Top Freezer...
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Aug 27, 2008 | Magic Chef Refrigerators
Magic chef- apartment size
The unit is sealed most tecks will not recharge to small to deal with. Most common cause for this is low freon. If someone has a clamp on amp meter the wire leading to the compressor will probibly show very low amps. showing a free flow compressor. Cheaper to replace.
Oct 23, 2007 | Magic Chef CTF2125 Top Freezer...
Magic Chef CTB1722 Top Freezer Refrigerator Logo
298 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
vince
Marvin
Marvin
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
