Try these steps:
1. First of all connect your PC Directly with Modem & check if you're able to go online or not.
2. If No , then contact your ISP.
3. If yes ,Disconnect CAT5 cable coming out of Modem from PC & connect into WAN port (on rear panel you'll find it) of Linksys WRT300N Router , After that on rear panel you'll find small hole with a Reset button inside it. Use needle or pen to press it quiet hard for 1 minutes continuosly, This'll restore all default settings.
4. After that give static IP - 192.168.1.2 to your PC ,subnet mask 255.255.255.0 ,default gateway - 192.168.1.1 & connect your PC directly with a LAN port on the back side of Router.
5. After that type 192.168.1.1 in the address bar of your explorer & login window will come , type username = admin & leave password field blank, then you'll get Blue coloured Router configuration page, From this page you can configure your Router.
6.Now if your Internet connection is Cable then default setting will work for you, However for DSL connection ,on this page you'll find internet connection type - selectiondrop down box - select PPPoE into it for DSL connection.
7. After that restart your computer & you should be able to go online.
