LaCie Big Disk
My 500 Big Disk just died.....power supply light flashes green ,instead of being on continuously , disk totally dead. Tried other PSU...same prob. Susspect small POWER Dist board in case (D2) . Can I get spare??
  • 1 more comment
  • FerryMac Apr 08, 2008
    The small green light on the power supply flickers instead of staying on. The blue light on the front of the box doesn't come on, and of course, the drive icon does not appear on the Mac desktop.
    Tried another LaCie power supply with exactly the same result.
  • davidhit Apr 27, 2008
    In my case I accidently plugged my Asus laptop power plug into the LACIE 500 gig external USB disc's power socket (SAME SIZE AND SHAPE!) and this has obviously blown something on the board inside the disc box. The power applied was 19 volts DC but the Lacie requires only 12V dc.
    You'd think there would be SOME tolerance to overloading considering the Lacie uses the same format (size and shape) for its external power connection. Why don't they use a proprietary shaped socket to prevent people from making this mistake; it must happen all the time. So, can I recover the data from the disc inside the Lacie box?
  • Anonymous Jan 16, 2009
    yes indeed - the green light on the power unit/transformer flashes weakly when the Big Disc (1 gb - almost a year old, so just in warranty thank goodness) is plugged in. Unplug the drive and green light is back to normal. LaCie sent me a new power unit (which seems to be the first thing they do-obviously cheapest and easiest) but exactly the same result.
    Obviously internal to the drive. Any thoughts about where the problem lies?
Yes, you can, friend of mine just got one out of ebay. French seller, hopes this helps, be patient...
Posted on Feb 12, 2008
The power supply light comes on,but when i plug it the light goes do i fix this problem .ty
when the green light on the power supply goes off or starts flashing when you plug it into the LaCie drive, there is a failure at the level of the internal electronic components. Either only on the interface, or on both the interface and one/both of the hard drive.
Usually, replacing the interface would solve this, but before doing so make sure that the internal hard drives electronic boards do not have any failure else they will cook your new interface. It is advised to consult someone skilled in electronics to inspect the internal components.
Dec 31, 2010 | LaCie Big Disk 500 GB Hard Drive
My Lacie 500 GB big disk constantly has the flashing blue light. The drive dose not spin all the time, when it does is constantly clicks but does not mount. I use an iMac and a MacBook Pro and neither will...
Hard drive is no good. If new replace under warranty. Given the bad luck you have had with this brand, you might consider replacing it with a different unit.
Jun 19, 2017 | LaCie Big Disk 500 GB Hard Drive
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Keep Losing Connection
try replacing the cable to it - ive notice once that is done dos not disconnect
Dec 31, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
LaCie Big Disk
Fixya is unable to suggest parts sources.
Dec 17, 2017 | LaCie 301294U 1TB Big Disk Extreme + with...
Trouble seeing my lacie drive possible mounting issue
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Aug 13, 2008 | LaCie Big Disk Extreme with Triple...
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Hard drive won't turn on
You could remove the drive if you can get the enclosure open and either install it in a new enclosure or as an additional HD inside your Pc. Good Luck.
Nov 17, 2006 | LaCie Big Disk (300872) 400 GB Hard Drive
Computers & Internet Logo
347 people viewed this question
David Payne
David Payne
