Problem with LG 15 inch monitor when i am switched on ,the screen should be very dark up to twenty...
(More)
Problem with LG 15 inch monitor when i am switched on ,the screen should be very dark up to twenty mins after onward its comes to normal,i found the reason because blue one of the primary colour is missing pls let me know the rectification Thanking You
I am having Samsung Syncmaster 753S. I am using it for last 5 years. Recently it is giving problem...
(More)
I am having Samsung Syncmaster 753S. I am using it for last 5 years. Recently it is giving problem while powering on. After 5-6 tries of on-off switch it gets powered on. And also once it gets powered on if I release a power on-off switch it again switched off. If I put small packing in the swich so as to keep the switch in pressed condition monitor remains on. What could be the problem?
hi thanks for being there, how can i get cct diagrams for crt monitors to help me in repairs?for...
(More)
hi thanks for being there, how can i get cct diagrams for crt monitors to help me in repairs?for example I have this viewsonic monitor model vcdts21490-1p whose horizontal width adjastment is not working and the raster dose not fill the crtscreen its on the center a look at the cctboard I found two totaly burnt out resistors,a blown out capasitor,shorting zd diode and a small transistor I need the diagram to find the values of this componets.
