Question about Kenmore 659 Electric Dryer
Kenmore dryer my kenmore dryer will start getting hot then it will trip the breaker. I plugged in another dryer and it works fine. Please help!!!
  • 32 Answers
Probably too late to help either of you since this is so old but there are two possibilities (assuming everything else works as normal).
If you really mean the circuit breaker to your house, then the heating element is bad and pulling too many amps. It may be shorting out when it gets hot due to the expansion of metal.
If you mean a switch on (or in) the dryer then you mean a thermal breaker (or thermal fuse). The most likely problem is that the exhaust vent for the dryer is plugged up with lint either within the dryer itself or in the part that is in your wall and exits someplace outside (could be as far as the roof). When the hot air can't escape the dryer overheats and shuts off to prevent a fire.
Posted on Sep 22, 2008
What part need to replace LG DLGX5171V keep getting power Trip or stop working
Check wires going to motor. Must be a short there.
Aug 16, 2017 | LG Dryers
Kenmore Series 80 Dryer won't start after Circuit breaker was tripped
A breaker thrown that many times indicates a serious electrical problem. You need to have the problem taken care of by an electrician. You should be worried about the safety of yourself and your family.
That being said, I would guess that breaker has gone bad and needs to be replaced.
Dec 18, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
This is an update to my previous problem with my electric Kenmore Dryer Model #88042700. The dryer appeared to have no power. I had checked the breakers and thought the one for the dryer was on. But it...
There is a reason it's tripping..First I would have the dryer cleaned out it sound like the unit is full of lint and is holding heat also bad ventilation in dryer exhaused. If it's tripping it's electrical
Sep 08, 2013 | Kenmore Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes '
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Runs for a few min then trips one of the 2 breakers. to make sure it was not the breakers,i switched the hot leads in the plug, and just as i thought the other breaker then tripped. so i assume the problem...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I would say that the motor is going bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Sep 01, 2010 | Kenmore 62602 Electric Dryer
Kenmore dryer surface gets extremely hot when
Classic of a clogged vent to the outside, Air out back of dryer should be same outside. Dryer will get hot and take to long to dry clothes with a clogged vent. Pls leave a FIXYA rating.
Aug 24, 2009 | Kenmore 63942 Dryer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 70 Series Dryer heats for 5 minutes then trips breaker.
Thanks for the question Your problem is with your breaker its weak and wont hold you reset it it works againfor a while Happens a lot When this happens again touch the breaker you will feel its hot also check the connections at dryer and at box where you plug your dryerin see if the prongs of the cord are lost its copper color . thanks for the question the appliance docs
Aug 24, 2008 | Kenmore 63942 Dryer
Kenmore 659 Electric Dryer Logo
73 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
