Question about Sharp AR-5316 Advanced Digital Imager Copier
There are white lines ony my photocopies
I replaces new drum and developer before one month ago. now there are vertical lines in all copies and printouts. there are no any errors in drum, Plese help me,.
  • anrua Jan 08, 2008
    THNX for your kindly response. they are White lines (smudges). it also happens when i get a printout. when i copy a full black page, there are these smudge lines always. (when using feeder and paper tray - no deference). i think this error is on printing section. not in the scanning section.
    waiting 4 u.
    thnx again
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,363 Answers
You need to be more specific with your diagnosis.
1- are they black or white lines?
2- does it happen when you put the paper in the feeder ( on top)?
3- what about if you put it directly on the glass?
4- do faxes come out OK?
Posted on Jan 07, 2008
6ya staff
SOURCE:
I Have a Konika Minolta bizhub 211. If I want to photocopy, it will display "caution machine trouble service call COF 32" or supplying tonner. Please what could be the cause of the problem.
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Sep 19, 2018 | Minolta Office Equipment & Supplies
I have ricoh aficio mp 2000, it's photocopy print black lining
if it background like faint toner all over copy need to replace developer powder/drum/blade/gears
Oct 08, 2011 | Ricoh Aficio MP 2000 Black and White...
My photocopier is printing black
Try removing the developer and reseat it.
Mar 09, 2011 | Canon NP 7130 Black and White Copier
Print out has white strips
Hi, white strips can vary depending on how you place your paper ie can be horizontal or vertical on the printed copy. Please check the following possibilities;
  1. Check that there is enough developer on the developer unit and that it is uniformly distributed on the magnet roller. If less, add a little or replace a new on, if there is some lines on the magnet roller, pour out and sieve the particle.
  2. If the steps above do not work, check the drum drive gear on the drive unit and replace if teeth are worn out.
  3. Replace a new drum and also the side seal which comes with the drum cleaner blade as they are the ones that removes the drum coating.
Please be cautious.
Nov 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
White stirkes in canon iR2016 photocopying result
It is either the drum unit or developer unit or transfer roller. if your counter is 150 000 copies change dev unit and transfere roller.
Oct 03, 2009 | Canon iR 2016i Black and White Copier
Lanier 5622 Prints vertical lines
You could remove the color and black&white drum units and check from below the units to visually observe lines on all the 4 drums. If so, you have to change the drum unit/units. Drums occassionally get damaged before life this way due to solid toner particles inside the toner bottle.Always "shake the toners very well" before replacement, and if you print rarely, then remove the toners and do the shaking to prevent clogging due to inactivity.
Aug 28, 2008 | Ricoh CL4000DN Laser Printer
We have a Canon iR2200 photocopier in our office but unfortunately everytime it photocopies something thick black lines appear on the copy. Can you please tell me how to solve this without calling out an...
You may want to check your drum unit.and your developer unit
your drum may cost about 60.00 or above
and your developer unit may cost about 250.00 or above
you can also check for white-out left on the scanner.This can also cost problem on printing effect.
Good luck
Jul 25, 2008 | Canon Office Equipment & Supplies
Pale, unreadable print
Make a copy and stop it in the middle of the procedure...take out your drum unit and check if all the image is there(on the drum and on your sheet)....if so, put everything back in position and make another copy and this time stop it just before it goes out....if you see your white line there you might have a fuser problem !
Mar 27, 2008 | Epson Aculaser C1100 Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
130 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
