Question about Epson Aculaser C1100 Printer
What is service code 527
Sir,
Kindly ask what is error 527 in epson c1100 and what part is defective,,how will i reset it..pls e-mail me,,Thank you and best regards
digifaxtrading@yahoo.com.ph
  • Epson Master
  • 691 Answers
The sensor under the photo conductor unit mounted on the metal bar is out of line and does not detect the dev unit in home position. Usually adjusting the sensor toward the dev fixes the issue.
Posted on Feb 20, 2008
Unidades de revelado atoradas con revelador no gira
Posted on Apr 28, 2009
Dear sir i install the cd for epson c1100 but it is showing service req e511 error on printers screen.. Please advice me
This isn't the Cd problem, it's the printer internal failure which can't be fixed by yourself. It needs service, means a technician to repair it. There are many causes, but I would suggest you to clean up the machine before you call the tech. You can use alcohol/spirit with cotton to clean all the interfaces including the cartridges contact points. Also don't forget to clean the waste ink tank which is fitted beside the cartridges compartment.
Or if it a new unit, you better get another replacement.
Good luck.
Thanks for using FixYa.
Jun 22, 2010 | Epson Aculaser C1100 Printer
Espon aculaser c1100 service req e511
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
May 14, 2010 | Epson Aculaser C1100 Printer
I HAVE E511 PROBLEM ON THE C1100
The "Service Req E511" error message means that part of the photoconductor unit called the transfer belt is not being detected. Please see the following Epson article which may help. http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1319
Jan 29, 2010 | Epson Aculaser C1100 Printer
My epson laser printer help help
hold down the dustbin button while switching on to reset the printer after cleaning. that worked for me.
Aug 19, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer suddenly stopped printing
To my knowledge Error Code E511 refers to photoconductor and/or its associated components. It is possible that:
  • the photoconductor requires a bit of cleaning and to be reseated snugly;
  • the black rubber conveyor (transfer) belt inside the photoconductor moved away from its path;
  • the silver square reflector on the transfer belt needs cleaning;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Epson Aculaser C1100 Printer
Service req. c0090 error code
Might be something mechanical, stuck or jammed. Perhaps a copy of the parts diagram and/or the multi part service manual might be of more help.
Jul 23, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Problem service required e511
Errrrmmmm, how about you tell us what the problem is.
Bloke walks into the doctor surgery and says "Doctor, help me I'm ill" the doctor asks "What is wrong with you?" to which the patient replys "You're the doctor, you tell me"!
Jul 05, 2008 | Epson Aculaser C1100 Printer
SERVICE REQ. C0082
C0082= CPU error ( TLB miss exception {Load/Fetch}), requires service personell to fix.
Jun 09, 2008 | Epson Aculaser C1100 Printer
E 527
Error message is listed as Deve Home Position Sensor Error, relates to signal not being received within the necessary time limit from to the sensor after rotation of Rotary Developer. A specialised problem requiring attention from a trained service person. Not something you could expect to fix yourself. See p198 of the Service Manual.
May 30, 2008 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
291 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
