The problem in the fuser unit.Clean and measurement the continuity of the heater lamp,thermistor and thermofuses.To reset enter in the SP mode Total clear 107 clear open the front door,turn OFF the main switch and unplugged the copiers.Wait 10 seconds plugged on closed the front door,and turn ON the main switch.
I have a Lanier MS 105 voice recorder that needs to be repaired. Can you repair older products such...
(More)
I have a Lanier MS 105 voice recorder that needs to be repaired. Can you repair older products such as this one?
DSm654 printer isn't compatible with vista - just says requires windows 95 or newer when cd is...
(More)
DSm654 printer isn't compatible with vista - just says requires windows 95 or newer when cd is inserted...help!
The multi function Photocopier was in good working condition but suddenly failed to function when...
(More)
The multi function Photocopier was in good working condition but suddenly failed to function when power was swiched on the following day . All Main fuses appear alright in the power supply unit. No information can be desplayed on the pannel. Usage in Nairobi Kenya.
