Sagem dvr recorder 6200t
NEW SOFTWARE SET UP STARTS 00, 01, SHOULD GO TO 04 BUT STOPS AND SAYS ER11 AND WILL NOT GO ANY FURTHER WHY?
  • 1 more comment
  • Anonymous Apr 26, 2008
    I have the same kind of problem but mine stops at ER10...
  • Anonymous Nov 25, 2008
    mine too stps at er10.....does any1 know what to do?
  • Anonymous Mar 18, 2014
    slow
WOW i have same problem but it stops at Er 09 ! This is soo weird
Can some one pleez help. :(
Posted on Aug 27, 2008
6ya staff
SOURCE:
Hdd recorder not working following switchover
Try a factory reset , should be in the onscreen menu under setup or something likewise .
Oct 03, 2012 | Sagem Televison & Video
Shows ER07 ER09 ER 01 Scrolls through 01 etc. and eventually shows ER09 SAGEM Model DVR 6200T/6400T
I had a very similar problem. On initially starting up it showed Pb03 then would cycle between er07 er09, er01 and counting up 00,01 up to 19 or so.
Nothing I did fixed it including turning it off for a long period and back on without the aerial.
Eventually I fixed it by pulling out the power cable while it was counting up and then on powering back up it started to initialise correctly. No idea what the problem was and why this fixed it but it might be worth a go. It didn't involve losing any recordings.
Jul 26, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
My Sagem DVR 6200T box is not working. The motor
Same thing happened to mine, problem is insufficient power to machine - solution is to purchase a new Power supply unit (lead
Jul 06, 2010 | Televison & Video
Er09 and Er07 black screened
Turn off the unit for 15 mins.
Turn back on with eveything connected except the antenna.
You will get an er 09 on the display.
Press OK on the remote.
With a bit of luck the box will reboot into standby.
Connect antenna and see how you get on.
Jan 07, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
After accepting a download of software on 09/11/09 my SAGEM HDD type DVR 6200T is just sitting with a blank screen on the TV and P603 flashing on the display. Hopw can I reset the system?
Although the Sagem PVR 6200 and 6200t are not specifically listed as models which have been known to have problems with the recent Freeview retune they are very closely related to the 6280/6240 models which are known to have issues and share most of the same firmware and software.
See the address below for a chart of affected models although it's proven not to be a comprehensive list, you'll need to contact Sagem directly on 0845 0900 316 to find out how to resolve this issue..
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Sorry I can't provide you with a definite solution but it's very likely that your model is one of those which only Sagem can sort out.
Please return the favour by rating my answer.
Nov 10, 2009 | Televison & Video
I have retuned my PVR 6200t recorder and have lost ITV and Channel 5 and several other channels. Any advice?
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune. Although the Sagem PVR 6200 and 6200t are not specifically listed as problem models they are very closely related to the 6280/6240 models and share most of the same firmware and software.
See the address below for a chart of affected models, you'll need to contact Sagem directly on 0845 0900 316 for either an over the air update or an update DVD depending upon the manufacturer.
Sep 30, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem 6200T
Sep 24, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
My sagem DVR 6200T UK displays ER 07 on the box
I HAVE HAD SAME PROBLEM. I HAVE TWO OF THESE RECORDERS AND ONE IS OK. I SWAPPED THE POWER LEADS FROM THE GOOD ONE TO THE ONE THAT IS NOT WORKING AND IT WORKED SO ALL YOU NEED IS A NEW POWER LEAD FROM SAGEM IN FRANCE.COST £10 PLUS POSTAGE.
CHEERS
Dec 17, 2008 | Televison & Video
Manual Needed.
Google It they are all there.
Dec 27, 2007 | Televison & Video
Televison & Video Logo
201 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
