they are just o-rings or just use teflon tape on the threads and screw them back into the tank Im assuming they are this type which if they are the larger type with a gasket contact the receiver mfg which they all have a plate welded onto them by law.
Was this helpful?
Yes
No
Popular Solutions for Ingersoll Rand - Rand Type -
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor...
Compressor keeps cutting out it is an Iwata silent Aire it only cuts out when the hose and gun are...
(More)
Compressor keeps cutting out it is an Iwata silent Aire it only cuts out when the hose and gun are attached.
I need to know how to replace the ball bearing seal on a compressor pump. Seal is located on pump on...
(More)
I need to know how to replace the ball bearing seal on a compressor pump. Seal is located on pump on the opisit side from the flywheel.
Certain nails cause my Akuzuki floor nailer to jam. Others (same type, brand, and size) work just...
(More)
Certain nails cause my Akuzuki floor nailer to jam. Others (same type, brand, and size) work just fine. How can I know which is a good box to purchase and which will jam?
need compressor parts for type 30 Model#64D9 Serial # is 3 Qt, 108472. One or two of the serial #...
(More)
need compressor parts for type 30 Model#64D9 Serial # is 3 Qt, 108472. One or two of the serial # may be wrong perhaps 4 @ 2
