Question about Sennheiser HD 555 Consumer Headphones
Sennheiser hd555 I require the connections for the 4 coloured wires to rewire a 3,5mm jack
  • Darkmentor Feb 09, 2009
    I have wired the black and white to the sleeve(ground), and wired the red to the tip. Blue is on ring.
    Does it make any difference? My headphones work just fine, but would it make any difference in volume perhaps?
White = tip. red = ring. blue and black = sleeve
Posted on Jan 04, 2009
6ya staff
SOURCE:
Which wire from indicator switch goes to flasher relay im using a narva 2 pin flasher relay in a 2002 holden rodeo one positive from battery an wht colour would it be from the switch or is it 2 wires
There could be no relay in the vehicle because it doesn't need one. CANbus vehicles tend to use a single module to carry out all the vehicle timing requirements - indicators, hazards, wipers, courtesy lights and so forth.
If the flashers don't work it would be better to repair the system than to rewire and use an outdated method, perhaps introducing further fault codes that might affect the operation of other stuff.
A little used hazard switch is a common cause of flasher failure...
If you really must rewire the system, the (ignition) live, as you say, goes to one side of the flasher unit and the other to the centre contact of the indicator switch though you will need a wiring diagram to identify the colour. There is no single universal colour code though if I was looking at an old British car I would expect to see a dark green wire with a thin black trace line.
A wiring diagram will be useful also for identifying the wiring to the lamps and separating the hazard switch wiring from the circuit. If there are two dashboard tell-tale lights the 2-pin relay will be ok but if there is only one you will need a 3 or 4 pin unit depending on whether electronic or electro-mechanical.
Jun 26, 2016 | Holden Cars & Trucks
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Is the creative hs-400 compatible with regular mp3 players?
It should be compatible with any MP3 players.
The headset has a universal headphone jack that is compatible with most (if not all) devices.
Apr 16, 2011 | Creative Labs HS-400 Headset
I'm trying to rewire my Harmon/Kardon M6531 speakers to a 3.5mm headphone jack. Thanks, Henry
thats easy get a headphone jack and solder two wires to the center pin of the jack then solder two wires to the other two connections then connect one set of wires to the center and top wire connection and the other two wires go to the center and the lower wire connection. plug it in and now sound will come through the speakers
Feb 28, 2011 | Office Equipment & Supplies
I HAVE LOST THE INSTRUCTIONS TO MY COMMTEL MOD X1 EXTENSION SOCKET AND NEED TO KNOW WHICH COLOUR WIRE GOES WHERE ??? PLEASE HELP
I lost mine too, saw this post, and then they turned up, so here you are:
COMMTEL
Surface Mounted 2/6a Slave Wall Plate - with ADSL Filter
Instructions
  • Remove wall plate back box by removing the two screws on the front face
  • Fix wall plate to skirting board or wall with screws supplied, allowing adequate space for cable entry
  • Insert exisiting telephone wires into screw connections on the ADSL face plate, following cable colour coding according to the list below, and ensure screws are correctly tightened
  • Screw wall plate onto the back box with the screws supplied, ensuring screws are sufficiently tightened
Cable Colour Coding
1. Not Used
2. Blue with white banding
3. Orange with white banding
4. White with orange banding
5. White with blue banding
6. Not Used
Information
  • No need for external filter
  • Surface fitting, replaces existing wallplate
  • Quick set-up
  • With back box
* If more than one phone or fax IS required to run off the same line, simply add more filters where required. Each individual piece of equipment will require a seperate ADSL filter
* Multiple telephone connections, long runs of cable (over 20m) or low quality telephone cable can adverely effect the performance of your connection speed
Safety Information
Before carrying out any electrical work, always switch off at the mains. If in doubt consult a qualified electrician.
Item Code: 41603016
Distributed by Commtel UK Ltd
www.commteluk.com
It might be worth mentioning that this filter swaps the polarity of the telephone wires: I don't know why. I rewired mine to use it as a master socket, and I have connected the other extensions to the filtered output. This can improve broadband speeds: see
http://www.rob-r.co.uk/other/UKphonecatwiring.htm
Oct 23, 2010 | Computers & Internet
Fitting new head in car require wiring diagram showing (L) live (E) earth and speaker wiring +_ colours.
Safer to REWIRE SUB Or Speaker With you own Wire then YOU Determin POS and Ground
Oct 20, 2010 | Car Audio & Video
What jack is compatible to laptop using shure
You have to connect the unbalanced output (the 6.3mm jack) to the laptop's line in (or mic with setting the rec level at very low settings) 3.5mm jack. In details the wiring should be as follows:
6,3mm jack shield to 3,5mm jack shield
6,3mm jack ring to 3,5mm jack shield
6,3mm jack tip to 3,5mm jack tip and ring
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 12, 2010 | Shure PGX14 Wireless Guitar/Bass System...
How do you rewire a trailer
Are you putting on a 4 wire flat connector? Trailer Wiring
4 Flat Small
Brown = Tail Lights
Green = Right Turn Signal & Brake Light
White = Ground
Yellow = Left Turn Signal & Brake Light
Feb 01, 2009 | 1995 Ford Escort
Sennheiser HD 555 Consumer Headphones Logo
720 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
