Ingersoll D2000 DVD Player
Do you know the code to make this player mult regional?
Ok, here it is...........
I just bought the £24.99 bargain as well..........
1. empty dvd tray
2. press 'menu' then '1' then '9' and up pops the multi region menu
easy peasy
its the same as a cyberhome ch dvd 300 (apparently)
Posted on Sep 07, 2009
Cant play a region 1 dvd
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Jul 12, 2011 | Audio Players & Recorders
Code region
power on the dvd
let it load and show no disc
open tray and enter '0' four times
region edit and region code appears with the default code
press 0 for region free and enter
region code should be 0
press pause on remote
power off and on again
Jan 03, 2009 | Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
NETFLIX DVD will not play ...
sounds like a region code block on your dvd player this is a risk unlocking region codes for player search internet explore region code for your model follow directions this is a use at own risk code
your dvd is region coded and your dvd player combo is region coded which code i dont know if live in united states the code for this region is one
May 17, 2008 | Sansui VRDVD4005 DVD Player/VCR
Multi region phillips dvd player
Is this a Multi-region Player ?
Some Players are region Set to play Only the region they, are intended For. i.e Region 1 = NTSC( USA ) Region 2 = (PAL ) UK. Region 6 = ( ASIA ) And so on.
If you need a multi-region hack for your player, Post here.
I do charge a Small fee for This service.
Mike @ compurepair.
Feb 29, 2008 | Philips DVP3140
Dvd player
Most of the DVDs available in India mostly use Region 2, Region 4 and Region 5 codes, all together in one DVD.
Education on region dvd codes:
http://en.wikipedia.org/wiki/DVD_region_code
If you want something on the cheaper side try a Philips DVP5982 Multi-Region DVD Player.
hope that helps!
Jan 31, 2008 | Panasonic DVD-S52 DVD Player
Unlock codes for TEAC PL-D2000
Comments:
To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region
Ensure TV monitor is on so and set to display DVD.
1. Turn system completely off.
2. Turn on system.
3. Open tray.
4. Using remote press and hold the return button.
5. While holding the RETURN button, press and hold the DISPLAY button.
6. You will see something like this displayed on screen: VER 1006 TE 3210
7. Release DISPLAY and RETURN buttons simultaneously.
8. Press the ANGLE button. You will see WRITING REGION ID displayed.
You can now play DVDs from any region.
Dec 28, 2007 | Teac PLD2000 System
PL-D2000 DVD Home theater System
Comments: To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region Ensure TV monitor is on so and set to display DVD. 1. Turn system completely off. 2. Turn on system. 3. Open tray. 4. Using remote press and hold the return button. 5. While holding the RETURN button, press and hold the DISPLAY button. 6. You will see something like this displayed on screen: VER 1006 TE 3210 7. Release DISPLAY and RETURN buttons simultaneously. 8. Press the ANGLE button. You will see WRITING REGION ID displayed. You can now play DVDs from any region. 0
May 27, 2007 | Teac PLD2000 System
Region free code
Hi...put in the DVD then press 1 3 7 9...they will appear as xxxx...then press country code...it will appear as digit, then press " play"
Oct 01, 2006 | Daewoo DVG-8500N DVD Player
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
