Question about Pioneer VSX-D511 Receiver
Vsx-d511 digital coax input
Hi, my receiver recently stopped producing sound on DVD/LD setting after a friend used it but he didn't unwire anything so i think it's just the settings. I have the receiver connected to my dvd player via the digital coax input. It seems to me that the issue is that the input signal refuses to change from ANALOG to DIGITAL, it merely toggles between DVD/LD ANALOG and DVD5.1ch ANALOG when pressing the signal select button. I don't have anything else connected other than the dvd player with the coax cable and i've tested the speakers and other inputs seem to be fine.. any ideas on how to fix this would be greatly appreciated.. any thoughts??
Thanks
  • mrkus Jan 09, 2008
    thanks, i've looked through the instruction manual online and it turns out the coax input has been switched off with the remote control.. and i just figured out how to turn it back on.
    cheers
    Genius:
  • 1,067 Answers
In dvd menu cheak output audio settings whats it on pcm or bitrate 5.1 ? how sthe cable cond does it work on other coxal units
Posted on Jan 08, 2008
6ya staff
SOURCE:
No sound on coax audio input from HDTV
Check your settings on your tv. You may have to turn off the internal tv speakers in the setup menu in order to get any audio output from the jacks on the back.
Dec 20, 2012 | Sony STR-DE835 Receiver
Pioneer VSX-D307 Receiver - no audio using DVD inputs
Sometimes the default on receivers in dvd mode will be digital. Make sure you are on an analog input or just try an optical or digital coax out of the dvd player and be done.
Jul 06, 2009 | Pioneer VSX-D307 Receiver
No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Oct 16, 2008 | Denon AVR-1602 Receiver
I need set up help
Most amps these days have to told which input is being used,ie if you have the dvd into dvd video input for picture and are useing coax or optical for sound you have to go into the setup menu on the amp and find the input menu and tell the amp the dvd is on optical or coax.
hope this helps.
CABLE GUY.
Jun 27, 2008 | Pioneer VSX-D510 Receiver
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Buzzing emitted by vsx-409
Could be the result of having DTS compatible equipment connected through the analog inputs on the VSX-409D. Noise and distortion will result as essentially the DTS signal is being played back undecoded. If this is the case you'll have to connect your LD or CD player through the digital connections (coax or optical) and set 'Signal Select' (button on front) to 'Digital'.
Jan 06, 2008 | Pioneer VSX-D409
Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Nov 28, 2007 | Sony STR-DA90ESG
Pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Aug 03, 2007 | Pioneer VSX-D511 Receiver
Digital Audio moved from TV/SAT to DVD/LD
Using the remote control, push the left arrow until display shows Coax1 (or 2, depending on your setup), then push the up arrow to set it to TV/SAT.
Conversely, depending on your setup, you can push the left arrow to display Comp1 (or2) then push the up arrow to set the correct video setting-- DVD/LD I assume.
Apr 09, 2007 | Pioneer VSX-D514 Receiver
Pioneer VSX-D511 Receiver Logo
202 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Anthony
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
