I cannot get my computer to start up. I am trying to figure out if it is the power supply causeing the problem. Should the LED on the power supply be bright at first and then go dim after connectint the power cord?
I guess u r a professional..as u r handling power supplies..
ur point of view has always a priority..
no 'the led on the power supply be bright at first and then go dim after connecting the power cord'..this happens when there's no/incorrect oscillation/frequency due to push-pull failure, incorrect wattage output etc.
well, itz likely to b the power supply causing it..!!..
however, check the following:
1) the smps itself may b defective/faulty..check the outputs of smps
viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg
& grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or
pwm switching regulator circuit..look for defective
protector-transformer/resistance(esp 4.7k)/mosfet..
2) if
itz not the smps, then it must b ur main/mother board..see with a debug
card for mb error..may b short..look for defective capacitors(esp above
1000mfd)/mosfets..go through the mb's south bridge n the circuit lie
around atx connector....
3)
remove/clean dust neatly..dust is non-uniform in nature n may cause
jam/short circuitry/excess resistance n many more..resulting an increase
in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink
Compound" (available in local electronics chip level spare market)
between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it
tightly in position..
5) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..
6) check cmos battery (above +3v)..
..plz give higher priority to step2 (as listed above) CAREFULLY..
always better to seek advise from ur system admin/vendor....
