Motherboards
Problem for HP Motherboards
Generic problem for all HP Motherboards
How to replace a motherboard in a hp pav...
By hshernandez1 on Nov 11, 2009
how to replace a motherboard in a hp pavillion dv2500 se
Solution #1
posted on Nov 11, 2009
Not Rated)
cmptrlink
Rank: Wiz
Rating: 82%, 106 votes
you need to deal it professionally....
Was this helpful?
Yes
No
Solution #2
Not Rated)
rain_catcher
Rank: Wiz
Rating: 78%, 85 votes
will will have to start by disconnecting all of the hardware { hard disk/ dvd or cd-rom . remove all led plugs make sure if you cant remember where everything goes you mark each thing you remove with numbered tape. number the part you removed and number where it cam from .
example hard drive will be mark as 1 and the plug that came from it will be also marked as 1.
now you will have to unscrew the stand outs. these are little lifts that support the board and keeps it from touching the frame. { note make sure to ware a esd> eletro static discharge bracelet or make sure there is no chance of static discharge. this will fry componets
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
dvd drive doesn't write but it reads. When writing using nero it displays power calibration error
Answer
hi there,,i need sound and wireless drivers for my nb610 model le1d plz
Answer
üdvözletem!?! Bocsánat a zavarásért, de volna egy kis... (More)
Answer
desde que compre el ordenador tengo problemas con el sonido no se si por algun fallo de la placa o... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
