Question about Pioneer AVH-P5700DVD Car DVD Player
Video not showing
When i connect a dvd player, i get sound but it wont show the video, just a black screen . The screen still shows like settings and things so i know it still works. my screen is showing black and asking for pbc code. there is audio
  • Anonymous Mar 29, 2014
    everything is on, all cables connected in both video and audio (in and outs) the monitor turns on but nothing will pop up on the actual screen
You have to bypass the parking brake. you do this by running the yellow black srtriped wire to the negative poularity of the parking brake wire.
Posted on Feb 03, 2008
My dvd player pdv 709 wont show the movie .it shows half
my Portable DVD Player just stop playing movies. i put a movie on and it want read or it will start the movie snd just stop and want play no more
Oct 23, 2009 | Durabrand PDV-709
DVD wont show picture i can hear sound but its just a blank screen
The emergency break wire is not connected correctly. This wire needs to be grounded to a chassis ground. Or the Yellow video cable is not connected or is not working correctly.
Jul 08, 2009 | Pioneer AVIC-D3 Car DVD Player
My portable COby DVD player stopped working. DVD rotates when I put it in by screen remains black... With TV out option sound comes out and picture/sound shows on TV once I connect it to DVD
I have had some very bad luck with Coby products and am sorry to hear that you have too but please make sure that the connector jack is clean and functioning properly. The connection jack has a device inside it that knows when the plug is inserted and then sends the audio and video out to the TV. If the connector is really dirty it could be that the connector is not working properly.
There isn't a lot more to look at unless there is some obvious problem with the screen such as a loose wire or a broken hinge.
Feb 26, 2009 | Coby TF-DVD8107 Portable DVD Player with...
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Samsung ht-tx72 Issue
GEnerally speaking that behavior suggests that the video signal is being lost for a second and returns. The easiest thing to try is to replace the connection cable (video). A bad connection there could cause this although moving the cable should make this happen at will. Check the DVd player on another TV if possible. If hte player is the cause, the "new" TV should show the same symptoms.
The only other possibility is that the DVD player is having a problem generating the video signal. This could be because the disc is not being read correctly (I would expect the sound to be effected as well) or the video processing section of hte DVD player is defective. This wil be a bit more difficult to find.
Can you try the cable and other TV and update this?
Thanks,
Dan
Jul 27, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
My DVD player, stopped playing in color!
check to see if the coding is set to PAL or NTSC, when watching in PAL, NTSC shows up in black and white. ( NTSC is normal for the USA and a hand full of other countries... PAL is used in ASIA, EUROPE, and most everywhwere else).
Oct 18, 2007 | Panasonic DVD-S29 DVD Player
Video not showing
what kind of connector do you use ? SCART, RCA composite or S-video ? Looks like cable or connector problem
May 24, 2007 | Alpine CVA-1003 Car Video Player
Video input from dvd player shows as black screen w/ squigly color lines
have you tried other devices for input...vcr, or other dvd players to see if it is a problem with the player or with the tv? Check the output setting for the dvd player (1080i etc) and ensure you are connecting to the proper inputs for either analog or digital signals (RCA inputs or RGB).
Aug 15, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Pioneer AVH-P5700DVD Car DVD Player Logo
481 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
