Not knowing what model machine you have, I would suggest, checking the door seal and making sure it has not worn out.
Also making sure the dishwasher door shuts firmly against the body. Some machines have a slight adjustment to the door hinges and also the door latch.
Let me know what brand and model machine you have. There is normally a manufacturers badge on the inside of the dishwasher door. Also let me know where you are observing the leak, is it on the bottom corner/s of the door hinge or in the bottom centre of the door.
I have an Asko 1325 dishwasher that has recently been attacked by rats. They tore through all the...
(More)
I have an Asko 1325 dishwasher that has recently been attacked by rats. They tore through all the insulation that was along the outside of the dishwasher. I don't know if this is just sound proofing or heat insulation, but it covers the outside of the dishwasher (which is mounted under our countertop. This is similar to the heat insulating liner of the oven (which I have also replaced - same problem). I can't seem to find a part that corresponds to this item, so I'm wondering if I can just go and buy some insulation or an easier to cut insulating board that would do the same function. Any suggestions as to if this is even okay or of a product that would provide superior sound dampening or insulation (not sure if insulation is even required)
