Heaters
Problem for Heaters
Generic problem for all Heaters
Our Fedders AirHandler Model#A24C1X kee...
By hvaciceman on Nov 11, 2009
our Fedders AirHandler Model#A24C1X keep 1 strip of heat when blower or nothing is on. have to unplug the red wire from NC on blower delay relay to stop it. blower relay Bd is new
Solution #1
posted on Nov 11, 2009
Somewhat Helpful)
james3751
Rank: Guru  Air Conditioners  Expert
Rating: 91%, 185 votes
Most of the time on Fedders unit one speed for heat comes off sequencer. This a low speed for heat. You may have bad sequencer. If your knowledge is limited about furnaces you may ahve to call service tech. But if you have some knowledge Replace the sequencer and follow woring diagram and you will be ok. Should solve problem. This time of year I replace dozens of sequencers due to this same problem. Rus
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
What is the best portable heater for a 700 sq ft area
Answer
how can you buy things for less than what they ask for?
Answer
I have a Reznor unit heater when it calls for heat fan comes on but ignitor will not spark. If I... (More)
Answer
my honeywell thermostat only works in the morning. we have a t834
Answer
I have had this heater for 3 years and now it works for runs for about 15 min then shuts off i have... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Heaters:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
