Sony Optiarc AD-7170S Burner
Problem for Sony Optiarc AD-7170S Burner
Optiarc rW 7170S does not read CD
By ziziana on Nov 11, 2009
Best Solution
posted on Nov 11, 2009
Very Helpful)
bhagyavichar
Rank: Guru  Computer Accessories  Expert
Rating: 95%, 2431 votes
do it only if u r a professional..
open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open up ur system cabinet and see if all the data cables n jumper settings at the back of the drives (master/slave selection)..itz most important..!!
however, at the bootup (0.29sec) start pressing briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del as applicable)..glance in the standard settings if r detected individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) : Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony Optiarc AD-7170S Burner
Questions and Unsolved Problems for Sony Optiarc AD-7170S Burner
Do you recommend Sony Optiarc AD-7170S Burner?
Answer
Answer
My laptop has the Optiarc DVD RW AD-7560A ATA Device installed...it used to work, now all of a... (More)
Answer
My drive is not working...my pc isnt reading it at all...like it doesnt exist...however, when I go... (More)
Answer
Cant write DVD9 (8GB). Need latest firmware. Running Windows 7.
Answer
Is the driver any different for XP than VISTA on a HP Pavillion dv6809wm?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD... Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
