Question about Microsoft Windows 98 for PC
Laptop won't startup HELLP!!!!!!!
I think i deleted too much off my laptop because it won't boot up anymore it comes up with invalid system i put in the windows 98 startup disk and it loads and comes up with start with cd-roim support start without it...etc so i put in stat without cd-rom support and it comes up with all loaded n stuff and then says type help ad press enter A:\ so i do and it comes up with the help and i read it and it says if it comes up with invalid system disk restart and type in A:\sys h or something and says required parameter missing..anyway point is computer will not start not in safe mode or anythin HELP!!!!!!!
  • 5 more comments
  • cheethamz17 Jan 08, 2008
    ummm im not sure wat u mean by configuration? how would i find out?
  • cheethamz17 Jan 09, 2008
    it is a toshiba satellite pro 430CDS
  • cheethamz17 Jan 13, 2008
    what is the HDD? or BIOS? that won't work i cant get into the computer to do that
    oh ok i get it thanks heaps i will try that...sorry im not that good with computers
  • cheethamz17 Jan 14, 2008
    thanks i will try that when i get the chance
  • cheethamz17 Feb 22, 2008
    how do i connect it to another pc?
  • eroberson Apr 25, 2009
    my dell d620 powers on but i have a black screen.
  • 65 Answers
Check your HDD on connecting it to other pc. Backup your data
Posted on Feb 20, 2008
  • 84 Answers
What is the configuration of your laptop - i can't tell you the solution without knowing that
Posted on Jan 07, 2008
  • 2 more comments
  • Nicu Jenunchi
    Nicu Jenunchi Jan 08, 2008
    what model is?
  • Nicu Jenunchi
    Nicu Jenunchi Jan 12, 2008
    Answer please
    In the BIOS you see the HDD?
    If yes - you must make a new 3.5" Win98 boot diskette
  • Nicu Jenunchi
    At a computer with win98 installed>
    Start->Control Panel-> Add/Remove programs-> on the third tab (make a 3.5" boot disk)
  • Nicu Jenunchi
    Nicu Jenunchi Jan 13, 2008
    immediately after power button press or [del] or F1 or F2 or F4 or F8 or F10. One of those must open to you the BIOS. There don't change anythink!!!!!!! Just look up for HDD Drive. If it is seen - try the boot diskette
    don't forget to vote
It takes too much time to boot,to open all programs & files
Perform the PC optimization, disk cleanup, delete all the unnecessary files and programs including TEMP, %temp% and Prefetch, also increase your virtual memory to take the effect.
You can also change your startup settings by going with the command in run window, 'msconfig' exclude semicolon. disabled all those programs which you think is not necessary for you during the startup. Run a full scan with the Malwarebytes Antimalware, and delete all the malicious objects found during the scan.
Restart your system to affect changes to take place.
Sep 02, 2013 | Acer Aspire 5560-Sb609 : 1.4GHz A6 Series...
Gateway laptop ml6732 has a startup repair screen and won't boot
Please re install OS .
Please specify what exactly went wrong when u used setup cd to re install
Jan 05, 2013 | Gateway ML6732 Notebook
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
My dynabook T2 series says invalid system disk.what do i do please help me need notebook for school!
You will need to go into the BIOS. Press the delete key as your laptop boots up. Once in the BIOS you will need to locate the disk bootup priority. You will need to set the 1st disk priority to the hard drive that has your operating system on it. It would also be a good idea to make sure that no USB flash drives are plugged into the laptop when you set this. After you have set the primary device save and exit the BIOS. Your PC should now reboot and hopefully boot into your hard drive.
May 31, 2011 | Computers & Internet
At boot-up I get "invalid
1) Go into your bios by pressing the Delete key.
2) Navigate to boot disk priority.
3) Set this to Primary master disk drive (The drive that your operating system is installed on.
4) The save and exit.
This should stop the message from coming up and solve your problem.
Please rate this solution by clicking on the thumbs up at the top right of this solution, it is much appreciated.
Nov 01, 2010 | ASUS A7V333 Motherboard
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
Windows freezes after startup
Its better to backup your data - booting from Ultimate Boot CD and backup to an external hard drive.
Try to do regular format or low level format to know the status of the hard disk
Feb 07, 2010 | HP Computers & Internet
I have a invalid boot diskette a error message. startup press f8 menu use arrows to safemode3.start windows in safe mode 4.delete any new startup software.
Oct 16, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
Microsoft Windows 98 for PC Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
