Question about O2 Xda II Smartphone
O2 xda hard button reset not working
I've tried to update the OS of my pc by downloading the updated Phone software via infra red (my usb cable not working), unfortunately i've run out of power for waiting so long. I decided to remove and its now totally dead.
Hi can you get this phone into bootloader mode if so you can revive it theres plenty of forums about the net which will help
but you will need your usb connection working
first thing i would do is uninstal the usb drivers,remove active sync and start a fresh
what os are running ?
regards
guest
Posted on Jan 08, 2008
Hello sir/madam, i'm karthik. i've a problem on my sony w200i. it's not gettin switched on. when i press the power button it's blinking with red color indicator in the power button. when...
you cant install the firmware of your mobile as that easy
you need some programs like : SETOOL and much experiense
THEN..
try that better way: FIRST : try to remove your battery and re insert it again then presss the C button at the same time when you press the power button. i think it will switch on.but if it doesnt work,,, try to update your mobile software via SONYERICSSON SOFTWARE UPDATER..
May 11, 2011 | Sony Ericsson W200i Cellular Phone
I want to update it software version via USB cable
Nokia 6300 firmware update
Subject: how to update firmware for Nokia 6300 to the latest official version
1. You need download and install NSU - Nokia Software Updater (http://europe.nokia.com/support/download-software/device-software-update/download#) and run it to ensure that all is ok! (don't forget to switch on and connect Nokia 6300 via USB with PC)
2. You need to download and install NSS (Nemesis Service Suite) (http://www.b-phreaks.co.uk/index.php?main_page=page_2), the latest version of NSS was 1.0.38.15 (select "Virtual USB Device" mode)
3. Close NSU if it's not closed and load NSS then click icon "Scan for new device"
4. Click icon "Phone Info" and button "Scan" inside it
5. If all is ok you'll see some lines with Phone Version, Phone IMEI and so on
6. Click button "Read" and remember your "Product Code"
7. If your want to clean your phone go to tab "Tools" and switch to subtab "Factory Setting", choose option "Full Factory" then press button "Reset" (NOTE!!! all personal data and settings will be cleared!)
8. Return to tab "Phone info" and type in the field "Product Code" the following code 0537621 (or any code from (http://www.expansys-usa.com/ft.aspx?k=96957)) for version 7.21, or code 0557624 (or any code from (http://www.a2phone.com/6300-rm-217-dp20-900-sw-0730exe)) for version 7.30, select option "Enable" then press button "Write"
9. Close NSS, run NSU
10. Now NSU should update firmware to version 7.21/7.30 (or any latter build) (http://europe.nokia.com/support/download-software/device-software-update/can-i-update)
11. Repeat stages 3 - 5
12. Type in the field "Product Code" the code that you remembered before, select option "Enable" then press button "Write"
13. Close NSS
14. Use you clean phone with new firmware!
Mar 17, 2010 | Nokia 6300 Cellular Phone
Software crushed!!!!
turn it off, then press the "comm manager" and "voice command" button at the same time then press reset. When the screen displays
the message "Press Send to restore.", then press "Send" button. That should do a hard reset. try that first.
Aug 14, 2009 | O2 Xda II mini
O2 xda 2 mini pocket pc usb connection problem
hi, i got the same problem, i even got a new sync and tried different ways to sort out but same problem??
email me plz for help
kind regards
Jul 13, 2008 | O2 Xda II Smartphone
Unable to boot up my O2 Xda Atom
Dear cafei,
Go to boot loader on your O2 XDA atom by removing batt+pressing camera button+plugging in the batt back WHILE still press holding the cam button the ue the stylus to press soft reset button, then connect to your pc via usb, then run the update program (most refer to it as DSUU, u can download one from seeo2.com) just wait for the progress to complete and you're done.
if in case you get stuck at 6%, unplug usb cable, remove battery, then insert battery while press holding the power button, while still holding the power button, press the reset button with the stylus, it should show the o2 splash, wait for any progress. then re-run the DSUU again to perform full flash.
disclaimer:
please take note that i did not suggest any 3-party rom, it is best if you try the O2-released ROM (or DSUU).
Jun 02, 2008 | O2 Xda Atom Exec Smartphone
O2 xda formatting
Quite possible the upgrade failed and has corrupted something.
You will need to find out how to perform a Cold reset as this should return it back to factory defaults.
See here for some assistance.
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
Apr 24, 2008 | O2 Xda IIs Pocket PC
O2 xda exec
This is the suggestion they provide on O2 website for such problems:
  • Perform a soft reset (PDA phone) or re-boot the device (Smartphone) and test again.
  • Perform a hard reset (PDA phone) or return to default settings (Smartphone) and test again. (read below before dong this)
  • Check that the application still fails to execute after you upgraded the ROM (OS) to the latest revision. If you haven't upgraded your ROM (OS) do so now and check again.
But before doing the hard reset, I suggest you try installing other camera software for windows mobile 5 and check if the camera still working (not a hardware problem). If its still fail, try the hard reset after backing up all you data.
Jan 31, 2008 | O2 Xda Atom Exec Smartphone
My o2 celphone won't turn on
O2 XDA Atom / O2 XDA Atom Pure / HP rw6828:
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device.
*Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
i hope it will help your prob.
Dec 01, 2007 | O2 XDA Mini S Smartphone
My O2 XDA IIs stoped working ....
try going to http://forum.xda-developers.com/ and searching there. they have loads of advice of the XDA IIs. Proberly need to start a fresh with it, try a hard reset as it seems your stuck in bootloader mode
Oct 05, 2007 | O2 Xda IIs Pocket PC
XDA Mini II won't advance past the align screen
refert to this, it may help: http://forum.brighthand.com/showthread.php?t=217656
Sep 14, 2007 | O2 Xda II mini
O2 Xda II Smartphone Logo
96 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
