Question about Compaq Presario 5000 PC Desktop
Help on my compaq
I have a major problem with my pc it's not booting into windows, it's just turning on and off, i have change the memory and processor could it be board
    Problem Solver:
  • 3 Answers
Do you have data on the hard drive... if not I will suggest a reformat of the hard drive and do a fresh installation... if that fails then check if your hard drive is a good one....I hope your boot sector is not damaged
Posted on Jan 07, 2008
6ya staff
SOURCE:
It turns into blue screen with white texts and from below, its says terminating (memory-something) and has a countdown... and reboots itself. computer: Compaq Presario PC SR5050NX
Its probably saying memory dump and the countdown. This is mostly encountered after some kinda change on the pc. It can be new hardware, software or just plain windows update. Lots of times it ends up being a corrupt driver. Try to boot in to safe mode and see doe sit still do same thing. if not than you know it is software related and you can do system restore. To boot in to safe mode on reboot keep on tapping key F8 and choose safe mode. Once in safe mode if it works go to start, all programs, accessories, system tools and choose system recovery. choose like a week back and click next and this will do a restore to when pc was working, fine. If you cant boot into safe mode it is possible it has issues with hardware and this should be checked out by a pc repair shop. Another option you can try if same mode dont work try to do same thing on boot keep on tapping key F8 and instead choosing safe mode try choosing Last Known Good Configuration. this is similar to restore. Hope this helps.
Apr 17, 2011 | Compaq Presario 2200 (292600-004) PC...
I bought the proper matching two 1Gig sticks of memory to upgrade my 2G mHz TC4200. I installed them and it wouldn't boot, so I swapped back the 1G stick to the original 512mHz chip and it booted. Then I...
Ok, Rob, did you buy the memory from Compaq/HP? Or is it a 3rd party set (ie. Viking, PNY, etc.)? Sometimes, Compaq/HP computers are VERY picky about the specifications of the memory that the mother boards will use.
If you bought them from a 3rd party vendor, I would recommend taking them back and exchanging them for another brand or even just another set of sticks, but, before we go that route, let's try something else.
Install a 1gb stick and the 512Mb stick and then go into the BIOS and see how much ram is being registered there. If it reads all 1.5Gb of ram, then we know it is something else, if not, then we have somewhere else to look.
Assuming the BIOS registered the full amount of ram, try removing the 512Mb stick and then boot the computer, enter the BIOS and see if it is reading the 1gb stick properly. Assuming it did register the 1gb properly, swap the 2 1gb sticks out and repeat. If it did NOT register the lone 1gb stick, try moving the 1 gb stick to the other socket, and checking the BIOS again. If that works, then swap the 1gb sticks out, repeat the BIOS check.
Assuming that after you swap out the 2 sticks and they both work as lone sticks, go back into the BIOS and look for an advanced page or an option to turn on a "Diagnostic Mode" or "Memory Test", and run the memory test on each stick- one sitck at a time, to see if there is a minor/major memory addressing issue, with either stick.
If they both pass individually, then, try reinstalling them both together and check to see if you can reach the BIOS with them both in place. If not try putting the 512 in the 0 or first memory slot and the 1gb in the second slot, then repeat the memory test, swap the 1gb sticks again, and repeat the memory test on the second stick- (the thinking here is that if it is not the memory sticks themselves, perhaps it is the motherboard or one of the sockets for the ram that is bad).
If you can reach the BIOS with both 1gb sticks in place, but, not actually boot to the operating system, then it is possibly a timing issue- this SHOULD BE AUTOMATICALLY configured, but, if you are an overclocker or a "performance wonk" you may have changed a relevant setting in the bios that controls the speed at which the memory and the processor interact. Or it could be a problem with windows hardware monitor not accepting the changes to the amount of memory in the machine. To test this possibility try going into "safe mode" at boot up, after the BIOS screen/Compaq logo has come and gone.
If you can boot into safe mode and not into regular mode, it is a problem with something in windows. Sometimes, just booting into safe mode alone will fix it, sometimes, it is necessary to run the restore DVD on the computer to fix the problem windows is having/ or alternatively reinstall windows without running the restore DVD, using this method will usually fix windows, with out deleting all of your data. You might have to reinstall a few programs afterward, but, your pictures, mp3s, document files, etc. will still be on the drive. Running the restore DVD almost always deletes your data, so USE THAT SOLUTION AS A VERY LAST RESORT, ONLY AFTER YOU HAVE TRIED EVERY other option I have given you.
Good luck, and hope this helps.
Sep 02, 2009 | Compaq tc4200 Tablet PC
My laptop was need to activation
A Compaq Presario 700US doesn't have the hardware to run Vista.
1.Processor: AMD Duron processor that operates at 900MHz
2.Ram Memory: 256MB of PC133 ram memory, (SDR Sdram that operates at 133MHz)
3.Graphics: VIA S3 Integrated graphics chip
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00255264&lc=en&dlc=en&cc=us&lang=en&product=95525
Your laptop will run Windows XP, but I would advise upping the ram memory amount to the maximum, for the best Windows XP experience. That would be 384MB of ram memory.
Change to Windows XP? Sure. Just buy the full installation disk of Windows XP. (About $95 US online)
Be sure to go into your BIOS Setup, and in Boot Options set the first boot device to CDROM.
Whoever tried to put Windows Vista on that laptop, didn't know what they were doing. That laptop Will Not run it!
Sep 01, 2009 | Compaq Presario 700 470024-192 Notebook
Got compaq presario will not boot up code purple do i need new mother board
Call Support for Compaq to get help if:
You have reinstalled windows and have added / changed the configuration (new memory, hard drive / other parts)
You are installing windows other than the orginal cd from Hp/Compaq
This is a "feature" of the motherboard, they may have you send the pc to them . take it to an authorized dealer.
-TechieJon
Jul 19, 2009 | Computers & Internet
Boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Doesnt boot to windows
Normally this means there is a problem with either the memory or the board. You might have to do more isolation such as trying the memory on another computer etc.
Jul 27, 2008 | HP Compaq Presario V2000 Notebook
RAM upgrade gone wrong?
Did you already try using last know good configuration?
When your computer boots instead of f10 press F8. Then select last known good configuration and enter.
if it didn't work try booting up the computer without the memory see if it will have the same problem.
May 12, 2008 | Compaq Presario 5000 PC Desktop
Needed Model# to help with Graphic Card
Your system model no. is :-PC182A-ABA SR1103WM NA430
Mar 18, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Need to get to setup menu
either the 64kb of bios memory is damaged and not allowing the system to pass the post check, or the processor is unable to find the boot.ini file because of a corrupt hard drive or file. The first thing to try is if you are using XP is to keep pressing F8 on start up and then when windows enters safe mode select the line 'Last known good configuration' and press enter for a restart, if there is nothing major wrong then the system will boot up. If it won't boot then you are going to need to set your notebook to boot from cd drive (F2 or del on boot up and enter the bios and change first boot device to cdrom) and boot up using your; or a borrowed Windows XP disc and perform a system repair. Post back for further instructions, as it may be the hard drive that is damaged.
Aug 22, 2007 | Compaq Presario 1275 Notebook
Compaq Presario 5000 PC Desktop Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
