I opened my Proxima X350 because I was having problems with the fan (mentioned by others here: green blinking light and shut down in 30 seconds). When I opened it up, though, I accidentally knocked off the remote sensor pin. This is the piece with 10 pins (5 on each side) soldered to the board that the remote control sensor plugs into. I am going to try to resolder it on without reapplying an solder (use the existing solder on the board). Unfortunately, I don't know which orientation to solder it on. There are 2 asymmetrical holes on the bottom, but I'm not sure how to use this. I can send pictures if anyone can help me with this issue. I have not tried to turn it on after the piece came off because I've been afraid I'll toast the board. Will it fry if I try to turn it on? Best case scenario is that have to use the keypad and can't use the remote and replacing the fans work well. Thank you.
my projector cant find any video source..On the menu screen, there it shows all the tabs, except I...
(More)
my projector cant find any video source..On the menu screen, there it shows all the tabs, except I only have access to 2 tabs.Theres no problem starting or shutting down everything else is normal.Bulb is fine no overheating,no flashing lights on the projector, please help...
i have a infocus in2102 and i just got a hdmi to vga cable so i could play my playstation 3 but i...
(More)
i have a infocus in2102 and i just got a hdmi to vga cable so i could play my playstation 3 but i just acts like it is not there when it is scanning i cannot get it to read that there is something in computer 1 vga
optoma ep1691 projector will not detect signal. have tried with usb and vga cable and with two...
(More)
optoma ep1691 projector will not detect signal. have tried with usb and vga cable and with two different laptops
Hi Is there any who know how to enter service menu for proxima x350 , ASK M3 or Yokogawa D-1200X ?...
(More)
Hi Is there any who know how to enter service menu for proxima x350 , ASK M3 or Yokogawa D-1200X ? Regards Galta
