I had the power go off last weekend and when it cam back on the player just wouldn't work, I checked and found power being received as the optic cable outlet behind the unit had the light on but there wasn't anything else happening.
If you could help me find the problem and a solution to the issue, it would be most appreceative.
Thank You,
Mario
Hi we had a power failure for several hours now my Samsung DVD/VIDEO player seems to have not power - do I chuck it (only 18 months old) and buy a new one or how do I fix it?? HELP model - VR320
-   Exactly the same No Power problem. I went on vacations, did my bit for the environment, by turning off power (pulled plug out). On return, dead as a dodo. I'll try and find a repair shop, taking the info. about the diode as a likely cause. Many thanks.- Going Green sure costs money...
-   alanbar
Feb 24, 2008
-   I had the same problem ie power to the unit but nothing happening.
This was while under warranty, it was collected and returned OK, the note said that they had fitted a 0402-001194 which I believe is a diode. A few months after warranty finnished the same happened again, does anyone know where I can obtain one of these diodes. -   geor49
Unit dead.
Local repair shop said it's un-econimical to repair.
Admitted they had no service manual.
Said they could 'have a look' but likely repair cost would be over $300. Charged me $50 for quote. Useless Gits.
My opinion & findings.
Power supply sensative to spikes.
I Suggest a power filter in-line with unit.
Disconnected all sub-boards from main.
Hiccuping PSU (5v wobbles between 2&3V).
Replace switchmode IC & feedback IC. No change.
Eventualy identified short-cct diode as listed below.
0402-001194 Diode is a Gen-purpose 200V 2A diode. I used a 1n4007 (1A), so I expect to have to replace it in future. It's "D1S35" located very close to right rear corner of main board, part of 15V and 12V rails. Next time I'll use a 'faster', higher rated diode.
I also had no clock progression. Time could be set but would not advance. Been like that for ages - I thought it was a user clock-setting error. Identified Dead 32.768 khz crystal (XT601).
Hi, Gladrags here again.
The $1 diode blew . I've used a BYX71-600 this time. Using a $20 diode is overkill I know, but that's what was sitting around. The 'front' of the diode package faces the rear of the DVD unit (for those without a ref chart).
Hi
The diode part number is SHG2D rated at 200 volts 2 amps, The printed circuit board number for this diode is D1S35, Location: back right hand corner of the printed circuit board, I used a BY299 rated at 800 volts 2 amps, Now working, Hope this helps,
John Porter.
I have a Samsung DVD-VR320 DVD recorder, two or three years old. It suddenly started giving me an...
(More)
I have a Samsung DVD-VR320 DVD recorder, two or three years old. It suddenly started giving me an error message when I attempt to record from tape to disc. I haven't changed anything - midway through a spindle of discs that has worked up until now, no connection changes - but now it records for 20-30 seconds than displays a "System error is found" message, after which the unit either powers down or it freezes on what would normally be the chapter creation screen. In either case, I usually have to power down to recover it.
The remote has ceased to respond when trying to set a programme or play back. It is a samsung...
(More)
The remote has ceased to respond when trying to set a programme or play back. It is a samsung dvd/vr320. Nearly 4 years old. When we took the cover off the remote it seemed to work again. It seemed to be the contacts.Is it just worn out. Where can I get another one?
I have a Samsung DVD-VR320 and it just started displaying the error "The disc can neither be...
(More)
I have a Samsung DVD-VR320 and it just started displaying the error "The disc can neither be played or recorded Please check disc"when I insert a new, blank DVD-R... any ideas? I cleaned the lens and still have the same problem.
