Question about Dell - Card, PCMCIA, Modem, 56K, V.90 CBM56WG-NOCBL (CBM56WGNOCBL)
How to switch on?
I'm a Radio & TV Serviceman and I have problem turning on a computer monitor without the hard disk. Presently I am repairing a monitor, but everytime I switch it on, the power went out.
Please help me what to do ?
Thank you very much!
  • Alanski Jan 08, 2008
    Thanks for the support!
    Actually I didn't fix the unit, I threw it in the garbage.
    Anyway, I really appreciate your help!
Well, thats great. I am still without a modem for my computer. I have a ACER 5100 laptop. I had to remove the software and reinstall but I lost my modem. What do I need to do, go and buy another disk and install it. PLEASE HELP
Posted on Jan 09, 2008
Dont be so upset.
You dont know the theory of your PC screenPowersupply so it happened.
With regards
Posted on Jan 08, 2008
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
May 21, 2016 | Dell E172FP 17" LCD Flat Panel Monitor
Lg flaton tv stand by
Im assuming thats all it will do. This could mean anything inside has caused this not to switch on and the only solution is to take it to a serviceman. This is assumig you have checked the remote control batteries are not flat and or you have tried switching it on at the tv
Mar 10, 2012 | Computers & Internet
No display in the monitor after switching on of the computer
My monitor is Samsung SyncMaster 753s. I am not getting the video output in the monitor. Monitor switches ON.
Apr 23, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Dell flat screen monitor does not come on after
Sounds like a capacitor on the power strip inside the monitor is failing.
The cost to repair can run $400.00. A tv repair shop may be able to fix it, but most technicians recommend buying a new monitor.
However, if you are experienced in electronics, you can disassemble the monitor and replace the capacitor. Radio Shack sells them for between $15 to $20.
Oct 10, 2009 | Dell E173FP 17" LCD Monitor
I have a optiquest q2202wb monitor and it has started to switch itself on and off continuously, it it a software problem and will installing new drivers solve this problem?
Hi
Yes and no. Yes the instaled drivers can cause this to happen but most likely something is going bad inside the monitor. You can send this to my company for repair or take it to a local serviceman.
Thanks
Jul 23, 2009 | Computers & Internet
The power on/off computer monitor is stuck. Can't turn it on or off. what can I do?
Put a power strip or new switch in the electric line to the monitor and use that switch, or buy a new switch from  radio shack and install it, if you are good at repairing electricial things. .
Jan 17, 2009 | Dell UltraSharp 1905FP LCD Monitor
Computer monitor screen is blue
Can you access the bios set up.
If the bios setup is running evrything is ok except the hard disk.
To find out if there is any problem with monitor just put off the monitor and disconnect it from the cpu. Then turn it back on. If the no signal message is coming, then monitor is ok.
Your hard disk is the main suspect
If the same blue screen comes then monitor need repairs.
You may also try with another monitor on your computer to see the results. If the sane happens it is the hard disk
Dec 18, 2008 | Acer 22" X223w LCD Monitor
MPEG4 HDD Player
Connect your HDD Player to your Television (TV) or Monitor using AV Cable; your TV will become a full of AV Entertainment System.It is Capable of Downloading Files from your Computer,HDD Player can be act as your Mobile Hard Disk that Back-up your Important Files .It is Compatible with 2.5" IDE hard disk up to 500GB (not included)
vk1_3.jpg To computer :
Connect your HDD Player to your Computer using the USB2.0 output cable (cable provided); your HDD Player will become your External Hard Disk that will be managed by your computer Window Software ,Back-up your Important Files. But it need additional 2.5" IDE hard disk to work .
To TV or Monitor :
Your TV will become a full of AV Entertainment System after you connect your HDD Player to your Television (TV) or Monitor using AV Cable.Play movies,mp3 and view picture on TV directly,
vk1_2.jpg Specifications:
  • Compatible with 2.5" IDE hard disk up to 500GB (not included)
  • It support NTFS and FAT32 formats
  • AV out to TV directly, VGA out to Monitor
  • When connected to your Computer, Do not connect your Power Supply
  • When connected to TV,it need power supply ( included,and which is compatible with your country)
  • Displays digital photos and movies on a TV, monitor without the use of desktop or laptop
  • Playable programs: MPEG4, Xvid, Divx, DVD,SVCD, VCD, JPEG, MP3,JPEG picture and MP3 song
  • Portable HDD function: USB 2.0 interface, windows management, be convenient for your study work and entertainment
  • Key button and Remote control operation
  • Supports TV type: PAL and NTSC
  • Audio outputs: stereo 2-ch (RCA)
  • Supports OS: Windows 98/98SE/2000/ME/XP
  • Portable design :132 x 80 x 19 mm
  • weight:215g
In the package comes: 2.5'' HDD player,USB cable,AV cables,remote control,manual ,power supply
Jan 29, 2008 | Computers & Internet
Thinkpad T20 no boot
TRY TO GO OLD SCHOOL AND USE A WIN 98 SART DISK OR TRY TAPPING F8 ALOT DURING START UP AND SELECT STEP BY STEP START
Dec 19, 2007 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
107 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
