Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
Air conditioner blower fan wont turn off
By sikfukn_tere on Nov 11, 2009
air conditioner blower fan wont turn off
Solution #1
posted on Nov 11, 2009
Not Rated)
james3751
Rank: Guru  Air Conditioners  Expert
Rating: 91%, 184 votes
If this is central AC unit check the fan motor to see if it will try to run. If the motor tries to run it may be capacitor easy to change. If not posible fan relay. Please keep in touch and I will help you with this problem. Rus Need more info please.
Was this helpful?
Yes
No
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
have an older Trane furnace. no 'board' just wires. thermostat kicks in, pilot works, ingnites, but... (More)
Answer
I have an Amana Gas Fired Furnace Model CCA24FCC. It recently started blowing cold air out of the... (More)
Answer
fan on out side unite will not come on makes a buzzing noise but still heats the house
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
