paper jam. At the exit side of paper, where the inks roll in and out sideway, there is uneven sponge sticking out a little on the left side. I believe it is causing the paper jam. How can it be fixed?
If you have some small twiser like you use to pull those nasty nose hairs, and pull the paper out with that. If that doesn't take a air compressor and gently blow it. A compress air will have some moisture in it and you don't want that to get on to the rollers.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX310 All-In-One
We have a canon MX310 all in one printer. We just replaced the FINE color cartridge and now the...
(More)
We have a canon MX310 all in one printer. We just replaced the FINE color cartridge and now the printer is displaying a "Check Ink U051 blk col" message which means that the cartridge is not compatible. However, we are sure we've got the right cartridge and that it is installed correctly. In the past, after replacing our blk cartridge, a similar message was displayed indicating that we had no black ink even though the cartridge had just been replaced. By holding down the stop/reset button for 5 seconds, we were able to override the message and continue printing just fine. This won't work in this situation. This is so frustrating and I'm not have good luck finding an answer myself. I'll be glad to hear what you have to say. Thanks in advance for the help. Cheers, Molly
Paper feeds skewed on canon mx310 printer. Cleaning rollers per manual instructions does not fix. ...
(More)
Paper feeds skewed on canon mx310 printer. Cleaning rollers per manual instructions does not fix. Trash or if there a cheap fix?
