Question about Sony Playstation 3 (PS3) Console
Puting the ps3 onlinw wired thought the pc
I have a ps3.with the ethernet cable i have plubed it in the pc.On the PS3 it says there is somethink worng with the conettion. can u help me work out the prompem.??
  • kiers Jan 07, 2008
    liljoepro. where can u get 1 from??. please tell me it you know
  • brendanh08 Jan 13, 2008
    i bought a router and can get online no problem but when i play online after a few moments i get disconnected i checked all the connections and everything seems ok
You need to get an ethernnet router,so both your PC and PS3 can be online.
Posted on Jan 07, 2008
PS3 Not Detecting Ethernet Cable
If its not the cable and not the switch port rhat its plugged in to, about rhe only thing left would be a failedfailing ethernet port on the ps3 itself. When you look into the actual port, do the wires look good? Try plugging the ps3 directly into some other ethernet device to see if you get a link anywhere. The actual link pulse and whole process of the initial handshakes, etc for AutoNegotiating the speed and duplex matching settings sometimes doesn't work with some brands of equipment. by using other equipment connected directly to your ps3, you'll simply be testing that the problem doesn't exist with another nic or port brand. Try several devices, preferably all devices with gigabit capability to support the Auto Mdix functions so that you don't have to use a crossover cable. If you connect the ps3 directly to a pc with only a 10/100 mbps adapter, you will likely need a special crossover cable to get that connection's link light lit up. If your ethernet switch supports configuration settings (not likely though if its a basic home internet router), try forcing the speed and duplex settings of the switch port to see if anything helps.
Nov 03, 2013 | Video Game Consoles & Games
How do I hook my ps3 to the internet using a eithernet cable.?
http://boardsus.playstation.com/playstat...
That website has a great guide on how to setup your ps3 for internet connection.
This is what you need to hook up to the net for your PS3
1.You need a MODEM which is the "box thing" that connects to your pc.
1. You need a ROUTER which connects to your MODEM and in to your PC. The router allows for both the PC and the PS3 to use the internet at teh same time. Unplug the wire that goes into your PC and plug into your ROUTER so that the modem is connected to the router not the PC
3. You need to connect your PS3 to the router with an ethernet cable and your PC to the router with an ethernet cable
4. Go to that web site and follow the instruction on how to set up and account on your PS3 and get going online and have fun!! Good luck!
Mar 30, 2011 | Sony PlayStation 3 40GB System
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Will not pick up my pc
then there is no connection from your ps3 to your computer/modem. make sure you have a phone wire connecting your modem to a pc, then have a ethernet cable connecting your ps3 to the modem. or you can keep the phone wire to the pc, and connect the ethernet cable to the ps3 and the pc.
Dec 14, 2009 | Sony Playstation 3 (PS3) Console
PS3 (80GB) Obtain IP Address : Failed, Help?
Try swapping the ends of the ethernet cable between your PS3 and the router. Otherwise, try a different ethernet cable. Also check that there are lights on by your ethernet port on the PS3 and the router.
Mar 31, 2009 | Ubi Soft Entertainment Tom Clancy's...
Internet connection
the Ps3 should connect fine, if you have your wired router set up right to automatically assign ip addresses...(DHCP)..in otherwords, anyone who comes over with a computer from anywhere..even me..should be able to plug a lan cable in to your router and it should connect without changing any settings. If this is true, then you should be able to go into your settings menu, select wired connection type, hook up your lan cable...then select auto and east for the settings for ethernet. this should work, if any pc works. If not, you may have to call AOL for info on how to properly configure your router and PS3. The network issue is most likely a AOL issue, and not a PS3 issue.
Dec 31, 2007 | Sony Playstation 3 (PS3) Console
PS3 internet problem
Hi, best way to connect the PS3 is to buy a router, wireless or wired router. and if you go for a wired one, connect the ethernet cable (RJ45) from the PS3 to the Router,
Other option is plug ethernet cable into PS3 & other end into the Network card which will be built into the base unit, otherwise you can buy a ethernet card which should cost you about £10.
but you will need the PC switch on, whenever you want to use the PS3, as well as you will have to configure the network setting to get it working,,
Have a good new year
John
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Connecting ps3 via t-mobile web n walk
now then or you hav to do is plug it to your pc go to internet connection t mobile properties then advanced allow to share to other connections then plug your cable to your pc from your ps3 you might have to turn your windows firewall off or just change the settings if you dont want 2 turn it off
Dec 09, 2007 | Sony Playstation 3 (PS3) Console
Ps3 wireless
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
Internet connection
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
