Air-O-Swiss U7142 Humidifier
Problem for Air-O-Swiss U7142 Humidifier
Air-o-Swiss room humidifier (model 7142) No mist flows
By lgolberg on Nov 11, 2009
We have an Air-o-Swiss room humidifier (model 7142). We have had it for two years and it worked perfectly for the past two winters. This year we have a problem. I have inserted a new Ionic Silver Stick and a new demineralization cartridge (soaked for at least 24 hours). The unit turns on, air flows, water flows from the tank to the well, but no mist comes out and no water gets used up even after hours of running. The humiditiy in the room does not increase. Is there something else I can do to make it work again?
Solution #1
posted on Nov 11, 2009
Somewhat Helpful)
fridgie22
Rank: Wiz
Rating: 83%, 11 votes
sounds like your heater element has broken
Was this helpful?
Yes
No
Popular Solutions for Air-O-Swiss U7142 Humidifier
Questions and Unsolved Problems for Air-O-Swiss U7142 Humidifier
Do you recommend Air-O-Swiss U7142 Humidifier?
Answer
Answer
Leaking. The white plastic circular ring in the base unit is cracked. This is part of the... (More)
Answer
When if fill the water tank with water and place it on the base the base fills up and leaks between... (More)
Answer
Air flows but no mist.
Answer
hi - i have a problem with my 7142 air-o-swiss humidifier - can you help?
Answer
i pushed the button, the signal shows the heat feature on, but the heat is still the exact same temp... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air-O-Swiss U7142 Humidifier:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2540
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
