fridge is no longer cold, makes a clicking sound about every two minutes. fridge is side by side Maytag 26.5 Cubic feet, about 10 years old. It is model # MSD2756AE. When talking to a dealer/repair place, they say it's probably the compressor and they won't replace compressors. They mentioned that it may be a relay/start switch that is the problem, but the only way to know is to have that replaced and then see if it works for the next week or two. Is there any way you can trouble shoot it without doing the repair ($125.00-150.00) that may not work. They said that if they did replace the compressor it would cost about $700.00 and so it's not worth doing. Any advice?
Either a bad relay on the compressor. Or a scized or locked up compresor. My co. in NJ gets $95 to replace the relay, $450. to change compressor. $25.00 just to check it out. The Dealer is always more $$
Shop around, Smaller companies, smaller price.
If your unit has a Embraco compressor it may just need a new relay. The Tecumseh compressors all went bad and now are replaced by Embraco's
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Maytag MSD2756G Side by Side
Freezer msd2735gr water runs onto floor under freezer side. Also, the freezer builds up ice in...
(More)
Freezer msd2735gr water runs onto floor under freezer side. Also, the freezer builds up ice in bottom.
ice maker does not work as it does not get any water the water come in at the filter but does not in...
(More)
ice maker does not work as it does not get any water the water come in at the filter but does not in ice.maker and the water despenser run very slow like it no pressure. thanks
My refrigerator recently occasionally not cool enough. Foods are softened. I pushed the temp control...
(More)
My refrigerator recently occasionally not cool enough. Foods are softened. I pushed the temp control to max but no noise heard. Sometime it starts cooling again. What is the problem?
